[GRASS-user] NVIZ can't allocate enough memory
Hi list,
I’m having some trouble using NVIZ. It’s worked before using similar data, so I’m not quite sure what the problem is. My goal is to overlay aerial photos over a digital surface model, but I always get errors that GRASS can’t allocate enough memory. It doesn’t matter how small I make the region. The same problem occurs when I try to do that without the aerial photos, or if I try to take e.g. the red band from the photo and use it as height without putting a photo on top of it. Here’s the error:
(Mon Jun 11 10:54:34 2012)
nviz elevation=dom_complete@PERMANENT
ERROR: G_malloc: unable to allocate 18446744071974792324 bytes at gsds.c:575
(Mon Jun 11 10:54:34 2012) Command finished (0 sec)
Does anybody know what could be the problem? If I’m interpreting the bytes correctly, that’d be about 10^10 gigabytes, which several orders of magnitude larger than the rasters involved. Thanks!
Best,
Daniel
On Mon, Jun 11, 2012 at 11:10 AM, Daniel Lee <lee@isi-solutions.org> wrote:
Hi list,
I'm having some trouble using NVIZ. It's worked before using similar data,
so I'm not quite sure what the problem is. My goal is to overlay aerial
can't allocate enough memory. It doesn't matter how small I make the region.
Please post
g.region -p
without putting a photo on top of it. Here's the error:
2012)
nviz
sec)
To me it looks like a g.region user error.
Hi Markus,
Here’s the output of g.region:
GRASS 6.4.2 (EPSG31467_GK3):~ > g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5867905.9439733
south: 5851898.90994448
west: 3430043.32300553
east: 3440047.55082599
nsres: 0.50020418
ewres: 0.50018638
rows: 32001
cols: 20001
cells: 640052001
Looks alright to me. I set it exactly to the raster in question by using g.region rast=dom_complete.
Any ideas? Thanks! :slight_smile:
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee@isi-solutions.org
Web: http://www.isi-solutions.org
2012/6/11 Markus Neteler <neteler@osgeo.org>
Hi list,
Please post
g.region -p
2012)
nviz
sec)
Daniel,
   That's more than 1,717,9869,182 Gigabytes of memory. It appears the
resolution of your aerial photograph is much too high.
Rich
Richard B. Shepard, Ph.D. | Integrity - Credibility - Innovation
Applied Ecosystem Services, Inc. | Helping Ensure Our Clients' Futures
<http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
I agree with Rich that your resolution might be too fine. I would either change the resolution to something coarser i. e. : g.region res=5
or make your region smaller. Definitely 640 million cells seems like a lot of cells to me.
Cheers.
On Mon, Jun 11, 2012 at 9:03 AM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Daniel,
That’s more than 1,717,9869,182 Gigabytes of memory. It appears the
Rich
Applied Ecosystem Services, Inc. | Helping Ensure Our Clients’ Futures
grass-user mailing list
grass-user@lists.osgeo.org
Thanks for the tips! I cropped the region and it worked like a charm :slight_smile:
Best,
Daniel
Hi list,
nviz
@devs: I would suggest to enrich this error message and print out
the current rows/cols along with a suggestion to verify the current region
settings.
18446744071974792324 = 0xffffffff9899ac84
Does anybody know what could be the problem? If I'm interpreting the bytes
correctly, that'd be about 10^10 gigabytes, which several orders of
A calculation has overflowed the range of a signed 32-bit integer
resulting in a negative value. This value has then been converted to a
signed 64-bit integer, and then to an unsigned 64-bit integer.
Here's the output of g.region:
rows: 32001
cols: 20001
cells: 640052001
At 4 bytes per cell, 640052001 cells = 2560208004 bytes.
2560208004 = 0x9899ac84
The maximum value representable by a 32-bit integer is 0x7fffffff =
2147483647.
Using an unsigned integer would eliminate the problem in this
particular case, but the region wouldn't need to be much larger in
order for that to be insufficient (specifically, 32001 x 33553 would
overflow).
The correct solution is to use "size_t" rather than "int". E.g. for
this specific case:
--- gsds.c (revision 52015)
+++ gsds.c (working copy)
@@ -481,7 +481,8 @@
int gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
     dataset *ds;
- int i, siz = 1;
+ int i;
+ size_t siz = 1;
     if ((ds = get_dataset(id))) {
More generally, it's important that the conversion comes before the
mulitply; e.g.:
  size_t cells = (size_t) rows * cols;
will work but:
  size_t cells = rows * cols;
won't; the calculation will be perfomed using "int", overflow, then
the overflowed result will be promoted.
However: the number of instances of this particular issue in the GRASS
source code is probably somewhere between "dozens" and "hundreds", and
there's no systematic way to identify them. Running test cases with a
region of >= 2^32 cells (or even >= 2^29 cells, i.e. >= 2^31 bytes at
4 bytes per cell) would find a lot of them, but it requires a 64-bit
system with plenty of RAM, and it's going to be slow.
On Tue, Jun 12, 2012 at 5:23 AM, Glynn Clements
rows: 32001
cols: 20001
cells: 640052001
2147483647.
overflow).
this specific case:
@@ -481,7 +481,8 @@
dataset *ds;
- int i, siz = 1;
+ int i;
+ size_t siz = 1;
if \(\(ds = get\_dataset\(id\)\)\) \{
mulitply; e.g.:
   size\_t cells = \(size\_t\) rows \* cols;
will work but:
   size\_t cells = rows \* cols;
I have started modifying some libs, but still need to fix (checks for)
return values.
Markus M
