[GRASS-user] nviz max resolution ppm image dump
My nviz dies with a segfault when I try to dump an image as maximum resolution ppm.
I have this same problem with grass 6.1 under FC 5, and under grass 5.4 under FC 4.
I can dump the other formats just fine.
The map products look great on the screen, but aren't much use if I can't get them into a high-res image file.
Does anyone have any advice on this problem?
Bill H.
William W. Hargrove hnw@fire.esd.ornl.gov
Environmental Sciences Division (865) 241-2748
Oak Ridge National Laboratory (865) 574-4665 (fax)
P.O. Box 2008, M.S. 6407 http://research.esd.ornl.gov/~hnw
Oak Ridge, TN 37830-6407 FedEx/UPS, use "Bethel Valley Rd."
resolution ppm.
5.4 under FC 4.
what's the date on the 6.1? 6.1.0 or 6.1-cvs? This was an old known
problem on 64bit &/or big endian (Mac G5), I had thought that it was
fixed by Glynn & crew some months ago.
http://intevation.de/rt/webrt?serial_num=3041
perhaps that bug referes to a slightly different problem?
Hamish
This is 6.1.0 built from source, running under 64-bit FC 5.
Here is what happens when I try to dump a max-res ppm:
recalculating normals...
Diagnostic: invalid command name "Nviz_animation_save" -- Save procedure for panel animation may not be defined
Diagnostic: invalid command name "Nviz_kanimator_save" -- Save procedure for panel kanimator may not be defined
Diagnostic: invalid command name "Nviz_query_save" -- Save procedure for panel query may not be defined
Diagnostic: invalid command name "Nviz_sdiff_save" -- Save procedure for panel sdiff may not be defined
Diagnostic: invalid command name "Nviz_label_save" -- Save procedure for panel label may not be defined
Diagnostic: invalid command name "Nviz_scale_save" -- Save procedure for panel scale may not be defined
Diagnostic: invalid command name "Nviz_pos_save" -- Save procedure for panel pos may not be defined
Diagnostic: invalid command name "Nviz_resize_save" -- Save procedure for panel resize may not be defined
Diagnostic: invalid command name "Nviz_pick_save" -- Save procedure for panel pick may not be defined
Diagnostic: invalid command name "Nviz_highlight_save" -- Save procedure for panel highlight may not be defined
Creating PBuffer Using GLX 1.3
Final Assembled Image will be 1 x 1
Writing Tile 1 of 1
Assembling Tiles
GLX -- destroy pbuffer
./donviz: line 2: 10088 Segmentation fault nviz elevation=elev48.new color=neon2.25 vector=states100,neondomains_states
Any ideas?
Bill H.
5.4 under FC 4.
Hamish
>>resolution ppm.
>>5.4 under FC 4.
I guess it is this bug after all:
Writing Tile 1 of 1
Assembling Tiles
Any ideas?
I get a segfault too: (32bit P4, 2gig RAM, Debian/stable)
Speafish with nviz window made to be large:
G63> nviz elevation.10m
Loading Data
Update elev null mask
Loading Data
translating colors from fp
r200_makeX86Normal3fv/197 CVAL 0 OFFSET 14 VAL 8260df0
r200_makeX86Normal3fv/198 CVAL 4 OFFSET 20 VAL 8260df4
r200_makeX86Normal3fv/199 CVAL 8 OFFSET 25 VAL 8260df8
r200_makeX86Normal3fv done
% recalculating normals...
Create PixMap Using GLX 1.1
Final Assembled Image will be 1935 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
MALLOC Failed
Segmentation fault
(hard to replicate)
The "MALLOC Failed" message comes from lib/ogsf/gsd_prim.c
int gsd_writeView(unsigned char **pixbuf, unsigned int xsize,
                  unsigned int ysize)
    /* Malloc Buffer for image */
    *pixbuf = malloc(xsize * ysize * 4);
    if (!*pixbuf) {
        fprintf(stderr, "MALLOC Failed\n");
        return (0);
    /* Read image buffer */
    glReadBuffer(GL_FRONT);
    /* Read Pixels into Buffer */
    glReadPixels(0, 0, xsize, ysize, GL_RGBA, GL_UNSIGNED_BYTE, *pixbuf);
    return (1);
with window left at starting size: [note larger "Final Assembled Size"]
Loading Data
Loading Data
r200_makeX86Normal3fv/197 CVAL 0 OFFSET 14 VAL 82613f8
r200_makeX86Normal3fv/198 CVAL 4 OFFSET 20 VAL 82613fc
r200_makeX86Normal3fv/199 CVAL 8 OFFSET 25 VAL 8261400
% Creating PBuffer Using GLX 1.3
Final Assembled Image will be 2048 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
pnmcat: Zero byte allocation
pnmcat failed to create assembled image
Check that pnmcat is installed and path is set
pnmcat: EOF / read error reading magic number
pnmcat failed to create assembled images
Destroy Pixmap and GLXPixmap
no segfault, NVIZ keeps running, these files are left behind:
(easy to replicate)
      0 Aug 29 17:24 spearNVhi2.ppm
3145745 Aug 29 17:24 spearNVhi2_1_1.ppm
3145745 Aug 29 17:24 spearNVhi2_1_2.ppm
     14 Aug 29 17:24 spearNVhi2_1_3.ppm
3145745 Aug 29 17:24 spearNVhi2_2_1.ppm
3145745 Aug 29 17:24 spearNVhi2_2_2.ppm
     14 Aug 29 17:24 spearNVhi2_2_3.ppm
     14 Aug 29 17:24 spearNVhi2_3_1.ppm
     14 Aug 29 17:24 spearNVhi2_3_2.ppm
     11 Aug 29 17:24 spearNVhi2_3_3.ppm
      0 Aug 29 17:24 spearNVhi2tmp1.ppm
      0 Aug 29 17:24 spearNVhi2tmp2.ppm
      0 Aug 29 17:24 spearNVhi2tmp3.ppm
      0 Aug 29 17:30 spearNVhi3.ppm.ppm
assembly of rows then full image fail as partials are not valid images
(14 byte ones). Images with data assemble, but contain random x-window
buffer weirdness: multi-virtual-desktop collages.
Summary: the partial tiles are broken.
I haven't tried it with just one workspace.
minimizing the NVIZ window (before clicking "ok" for the output
filename) gives the same result.
at the end of the bug report Glynn offers a reason, but I have no idea
where to go from there. Dumb debugging effort: I still get the broken
result if I comment out "Nset_cancel_func update" in
  visualization/nviz/scripts/nviz2.2_script
and rebuild nviz.
Hamish
Thanks, Hamish:
Notice that my error:
Writing Tile 1 of 1
Assembling Tiles
is a little different from your error:
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
MALLOC Failed
Mine does not seem to read the PBuffer screen size correctly from GLX, while yours does.
Yours fails on the MALLOC, while mine just segfaults.
The relevant code seems to be in do_zoom.c, but I can't make much sense out of it.
Perhaps Covill can help?
Bill H.
5.4 under FC 4.
Writing Tile 1 of 1
Assembling Tiles
Any ideas?
Loading Data
Loading Data
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
MALLOC Failed
Segmentation fault
(hard to replicate)
                 unsigned int ysize)
   if (!*pixbuf) {
       return (0);
   return (1);
Loading Data
Loading Data
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
(easy to replicate)
and rebuild nviz.
Hamish
Thanks, Hamish:
Writing Tile 1 of 1
Assembling Tiles
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
MALLOC Failed
Note that setting the environment variables:
  GRASS_NO_GLX_PBUFFERS
  GRASS_NO_GLX_PIXMAPS
will disable use of these features, in case of problems with your
OpenGL setup (libraries or X server). Their values don't matter, only
whether or not they are set.
Binbit S.A de C.V
Antoni Muntaner
C.E.O
http://www.binbit.com
Dear friends from GrassList we are located on Mexico and we are looking for
find several partners in other countries, interested in be partners with us,
and make business with SMS premium solutions... If somebody is interested..
Please send us a details request.
Best regards
Alfonso Ruiz
Binbit S.A de C.V
These should be added to lib/init/variables.html
Setting those make no difference to this bug however:
#with GLX
G63 > nviz elevation.10m
Loading Data
Loading Data
Final Assembled Image will be 1929 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
pnmcat: EOF / read error reading a row of pixels
#without GLX
G63> export GRASS_NO_GLX_PBUFFERS=TRUE
G63> export GRASS_NO_GLX_PIXMAPS=TRUE
Loading Data
Loading Data
r200_makeX86Normal3fv/197 CVAL 0 OFFSET 14 VAL 8254e28
r200_makeX86Normal3fv/198 CVAL 4 OFFSET 20 VAL 8254e2c
r200_makeX86Normal3fv/199 CVAL 8 OFFSET 25 VAL 8254e30
% Final Assembled Image will be 1904 x 2048
Writing Tile 1 of 9
Writing Tile 2 of 9
Writing Tile 3 of 9
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
      0 Aug 30 11:44 test7.ppm
     13 Aug 30 11:44 test7_3_1.ppm
     13 Aug 30 11:44 test7_3_2.ppm
     11 Aug 30 11:44 test7_3_3.ppm
5925905 Aug 30 11:44 test7tmp1.ppm
5925905 Aug 30 11:44 test7tmp2.ppm
      0 Aug 30 11:44 test7tmp3.ppm
      0 Aug 30 11:45 test8.ppm
2924560 Aug 30 11:45 test8_1_1.ppm
2924560 Aug 30 11:45 test8_1_2.ppm
     14 Aug 30 11:45 test8_1_3.ppm
2924560 Aug 30 11:45 test8_2_1.ppm
2924560 Aug 30 11:45 test8_2_2.ppm
     14 Aug 30 11:45 test8_2_3.ppm
     13 Aug 30 11:45 test8_3_1.ppm
     13 Aug 30 11:45 test8_3_2.ppm
     11 Aug 30 11:45 test8_3_3.ppm
      0 Aug 30 11:45 test8tmp1.ppm
      0 Aug 30 11:45 test8tmp2.ppm
      0 Aug 30 11:45 test8tmp3.ppm
Note partials are constructed in the output save dir, not $MAPSET/.tmp/.
I guess that's not a problem.
Hamish
I'll do that.
#with GLX
Assembling Tiles
#without GLX
Assembling Tiles
Well, it appears to make *some* difference, i.e. you're getting a
different error message.
Does removing the following from nviz2.2_script help?
  # Set the cancel function for drawing
Hamish, Glynn:
The 6.1.0 version of nviz dumps high res ppms perfectly after I comment out the off-screen section.
So the bug that remains in the subsequent versions must come from code changes introduced since then.
Bill H.
I'll do that.
#with GLX
Assembling Tiles
#without GLX
Assembling Tiles
The biggest change since 6.1 is that Togl has been updated to version
1.7.
Have you tried commenting out the following from nviz2.2_script (line
879)?
