[GRASS-user] nviz: Multiple Vector Maps Draped on Raster DEM
No, actually you can load more vector layers over a raster map using nviz
for example you can type
nviz elevation=dem vect=streets,streams
and you will be loading two vector layers (streets and streams) over a raster dem map.
If you have nviz already loaded you have to go to Visualize/Lines 3D Polygons or Points and use “New” button. To switch the layer configuration just pick the button with name of the layer in front of “Current”.
Juan David Rondón Díaz
Tesista de Ingeniería Ambiental
Universidad Distrital Francisco José de Caldas
openSUSE.org
