I’m using GRASS 6.4.2RC1-1 but cannot get a high resolution from an input dem/raster surface that i’ve been using with previous versions of Grass. NVIZ will display the raster okay but will not allow a high res render. I understand NVIZ is in transition to python but which Grass version (windows installer) does NVIZ work fully.
I'm using GRASS 6.4.2RC1-1 but cannot get a high resolution from an input
OSGeo4W? Than I suggest GRASS 6.4.2RC1-2.
dem/raster surface that i've been using with previous versions of Grass.
Do you mean wxNviz [1]? GRASS 6 contains quite old version of wxNviz
(Google Summer of Code 2008/2010), improved version of wxNviz (Google
Summer of Code 2011 [2]) is available in GRASS 7 [3] or you can try
OSGeo4W package `grass70-dev`.
