[GRASS-user] nviz - thematic mapping for vector points
I have problem understanding nviz settings for 3d vector points (Vector
Points Panel).
I have some point data (converted to 3D vector) and columns x, y, z,
annual (fp precipitation values), annual_int (integer precipitation
values), etc.
I want to get the spheres coloured based on z (elevation) and sized
(=volume) based on the precipitation values upon the srtm3_dem. Hence, I
use the "thematic mapping for vector points". No matter what I try, I
don't it right.
Color(s) - The colors do not correspond to the ones that the "Auto" &
"Apply" is supposed to set. I get sometimes black spheres although there
is no black color defined.
Size - Some spheres just dissapear. But I checked the values from the
column I use and I don't find that they so much different. And I though
that setting the "icon size" is some kind of scaling.
Is there anything special that I have to check? BTW, the documentation
of nviz looks outdated (?). Below some code.
Nikos
# check range of srtm3
r.info srtm3_for_global_rad -r
min=-10
max=2503
# set region
g.region rast=srtm3_for_global_rad b=-10 t=2503 tbres=10 res3=0:00:03
-pa3
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 39:05:38.098741N
south: 38:23:35.098741N
west: 21:21:01.344612E
east: 22:26:13.344612E
top: 2510.00000000
bottom: -10.00000000
nsres: 0:00:03
nsres3: 0:00:03
ewres: 0:00:03
ewres3: 0:00:03
tbres: 10
rows: 841
rows3: 841
cols: 1304
cols3: 1304
depths: 252
cells: 1096664
3dcells: 276359328
  ## even if working in WGS84, is the top, bottom to be defined
(always?) in metres?
  ## does, and how, the top-bottom and res3 resolution definitions
affect nviz?
# converting 2D points to 3D:
v.drape input="precipitation" rast="srtm3_for_global_rad"
output="precipitation_3d" method="bilinear"
# check for 3D-ness
v.info precipitation_3d | grep 3D
| Map is 3D: Yes |
# launch nviz
nviz elev=srtm3_for_global_rad points=precipitation_3d
  ## first image looks ok. Now working on colors/sizes is a mess :-?
Points Panel).
values), etc.
don't it right.
No matter what I do I can't get "scaled" coloring or (re-)sizing of 3d
points in nviz. I see a message in the console though (is it relevant?):
  "Dev note: Adapted sites library used for vector points. (module
should be updated to GRASS 6 vector library)"
Nikos
> Points Panel).
> values), etc.
> don't it right.
using grass-6.4.0svn
