[GRASS-user] NVIZ - tiled legend in maximum resolution ppm
Hi
Like in the subject.
In Nviz when I need to save visualisation as maximum rosolution ppm, and I have legend added, the legend (but not the north arrow!) is tiled over the image regulary 12 times.
There are no such problems in saving as normal ppm or tif.
If needed, I can send picture on priv with that.
regards
Jarek
is the rest of the image ok, is it just the legend which is repeated?
see bug #3041
  https://intevation.de/rt/webrt?serial_num=3041
does it work ok for you if you use GRASS 6.2.2?
does it work ok if you don't use a legend?
Hamish
____________________________________________________________________________________
Got a little couch potato?
Check out fun summer activities for kids.
http://search.yahoo.com/search?fr=oni_on_mail&p=summer+activities+for+kids&cs=bz
see bug #3041
I tried by I cannot place a scale in grass 6.2.2 (in fact I almost have never used that version of grass, so cannot say why) so I cannot answer this
All render ok exept legend, anyway legend is added or not
Jarek
Hamish:
> see bug #3041
Jarek:
answer this
I would suggest filing a new bug report in the bug tracker for this.
For now as a work-around you might make an image with and without the
legend, and then cup&paste the legend into the clean version in a paint
program.
Hamish
