Hi everyone,
I'm trying to visualize a DEM that I've generated of the buildings of a
city. In each cell I have the meters of elevation. When I try to see it with
NVIZ I found that it makes something like interpolation, smoothing the
corners like it was a DEM of terrain instead of "hard edges" (i don't know
how to say it).
Anyone knows how could i get a correct visualization of the buildings?? It
would be very important to me getting it. I have the raster, and the
vectorial with the areas and the attribute.
On Fri, Oct 30, 2009 at 10:24 AM, incanus <andresfr@unizar.es> wrote:
Hi everyone,
how to say it).
For speed reasons, NVIZ is per default (typically) starting with a
reduced visualization.
Hi everyone,
how to say it).
As everyone can see, the "walls" are transparent. I've tried to resample the
color file to the resolution of the elevation file, and the result is the
same.
I would appreciate any comment os suggest about this, if someone had seen
something similar.
thanx,
Andres
Hi everyone,
with
know
how to say it).
Forget it! and thanx again Markus,
finally, I remember that in my DEM there was 0-values and null-values.
I replaced the null's by 0's and it works perfect!
the color file to the resolution of the elevation file, and the result is
the same.
something similar.
thanx,
Andres
Hi everyone,
with
know
how to say it).
