[GRASS-user] NVIZperspective
Hello All,
I’m trying to do some simulation of view in NVIZ and I have to look an object at a fix distance from a fix point… so I usually use the “position” panel (where I can set coords and elevation of the two points) but sometimes it happens that when you obtain this view you see some white space under your “feet” so I tried to avoid this modifying the perspective parameter (slide in the main panel).
Doing this I noted that if I modify the perspective parameter the distance of observation changes; what does this angle represent? who can explain me its specific meaning? and why if I increase/diminish it the observed object goes/comes far/near?
Thank you in advance.
Annalisa
Hi Annalisa,
On Tue, Jul 14, 2009 at 9:36 AM, Annalisa Minelli<annagrass6@gmail.com> wrote:
Hello All,
I'm trying to do some simulation of view in NVIZ and I have to look an
object at a fix distance from a fix point.. so I usually use the "position"
your "feet" so I tried to avoid this modifying the perspective parameter
the tcltk nviz isn't "the future", perhaps you could try the new nviz based
on python? It can be controlled via command line which might help a lot.
Thanks Markus,
I’ll try and see if it this way can clear up my theoretical-doubts.:slight_smile:
Annalisa
2009/7/15 Markus Neteler <neteler@osgeo.org>
Hi Annalisa,
Hello All,
the tcltk nviz isn’t “the future”, perhaps you could try the new nviz based
...and keep table data
I am going to merge some vector areas sharing a common value. I want to
keep the information in my table, but I can't find a way to "stamp out"
the desired areas and "replace" them with desired information.
Is there something like union touching areas and keep information (table
entries, cat) of one of them I have not seen?
Thanks in advance,
achim
Ok. I did it with:
v.extract: extracting the areas I dont want to merge
v.overlay: union the extracted with the dissolved rest
so I keep the information of the not-to-be-merged areas. Only thing is,
that I have to generate some new information for the dissolved areas. In
this case its not that necessary.
But: I am still looking for a straight way to merge some (eg. 2)
connected areas and keep the information of one of them!
achim
Thanks in advance,
achim
grass-user mailing list
grass-user@lists.osgeo.org
