Hello Moritz,
Hello,
Some of my colleagues use eCognition for remote sensing data
classification. After having done so for teaching, we are now looking
into the possibilities of replacing proprietary with open source
solutions in research.eCognition uses an object-based approach to classification as opposed to
pixel-based. As they put it in their brochure:"The technology examines pixels not in isolation, but in context. It
builds up a picture iteratively, recognizing groups of pixels as objects.
Just like the human mind, it uses the color, shape, texture and size of
objects, as well as their context and relationships to draw the same
conclusions and inferences that an experienced analyst would draw."
The issue about how to emulate the eCog-approach into GRASS has been around for a while. Here are my two eurocents of knowledge:
eCog consists of several algorithms. First, a segmenting tool (patented...) is used to divide a multispectral image stack into segments. Then, a knowledge-based (fuzzy) merging process gets you to the object-representation.
So to do it with GRASS, we need to have a multispectral segmenting tool plus "the object stuff".
I am not sure if there are any FOSS-segmenting tools in the works that do their job without signature files [medical imaging tools, maybe?].
For the next step, the abstraction from spatial segments to objects, object-oriented grass-friendly environments such as R or CLIPS/CAPE could be used to create a prototype/demonstrator. However, the performance for large data-sets might be significantly below a c/c++ implementation.
Peter
Is something like this possible in GRASS ?
Or are there any other open source solutions using this approach ?Moritz
Dr. Peter Löwe
<peter.loewe@gmx.de>
GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS.
Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail
