Hi everyone,
Is there a way to obtain the long/lat of a point from GRASS? I need to import some locations from a layer into a GPS and I do not see an easy way to do this. Thanks for any help.
Chris
Sent from Windows Mail
Hi everyone,
Chris
What you need is the v.to.db module. It takes an “option=” parameter which you set to “coor” and also add the “column=” parameter with the names of the database columns that will hold the long/lat coordinates.
On 2014-07-22 22:14, cboscari@sbcglobal.net wrote:
Hi everyone,
ChrisSent from Windows Mail
This mail was received via Mail-SeCure System.
_______________________________________________ grass-user mailing list [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) [http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user) This mail was received via Mail-SeCure System.
I was thinking, v.out.ogr to either GPX or GPSBabel format
http://www.gdal.org/ogr_formats.html
Those formats should be easy to load onto a GPS.
Enjoy,
Alex
On 07/22/2014 12:32 PM, Micha Silver wrote:
What you need is the v.to.db module. It takes an "option=" parameter which you
set to "coor" and also add the "column=" parameter with the names of the
database columns that will hold the long/lat coordinates.On 2014-07-22 22:14, cboscari@sbcglobal.net wrote:
Hi everyone,
