[GRASS-user] Obtaining unique nodes from a topology
Hi all
I’ve used Grass to build a topology out of a polygon shapefile, so far so good.
I now need to export it as an arc-node topology (i.e. boundaries with startnode_id, endnode_id) which I will then use in PostGIS.
Does anyone know of a way to get the nodes from the topology and attach these attributes to the boundaries?
I know I can get the start/end coordinates, but I need the unique nodes and their ids.
Thanks
Will Temperley
Hi Will,
for lines you can use
v.to.db -p map=... option=start
-p to print your result
option=start to get start points
option=end to get end points
the result looks like
cat|x|y|z
without -p you can upload the results to the table with:
columns=x,y(,z)
Hope it helps,
Achim
William Temperley schrieb:
Hi all
I've used Grass to build a topology out of a polygon shapefile, so far so good.
Thanks
Will Temperley
grass-user mailing list
grass-user@lists.osgeo.org
Hi Achim
Thanks - but what I really want is a list of unique nodes (i.e. where three boundaries meet, there would be one node, with an id) and assign this id to the relevant boundaries. Perhaps that isn’t possible. It might be easier to do this in PostGIS. I need to be able to run recursive queries in PostGIS to pick up connected boundaries.
Will
2010/1/15 Achim Kisseler <ak7@jupiter.uni-freiburg.de>
Hi Will,
v.to.db -p map=… option=start
cat|x|y|z
columns=x,y(,z)
Hope it helps,
Achim
Hi all
Thanks
Will Temperley
Hi Will,
I think it is possible:
building a network from boundaries with
v.net
and then using the report option in v.net
it is not possible to update the table with these infos, but it is possible to save the results in a list, import this to your database and connect these infos to the table.
Achim
Hi Achim
Thanks - but what I really want is a list of unique nodes (i.e. where three boundaries meet, there would be one node, with an id) and assign this id to the relevant boundaries. Perhaps that isn't possible. It might be easier to do this in PostGIS. I need to be able to run recursive queries in PostGIS to pick up connected boundaries.
Will
2010/1/15 Achim Kisseler <ak7@jupiter.uni-freiburg.de <mailto:ak7@jupiter.uni-freiburg.de>>
    Hi Will,
    cat|x|y|z
    columns=x,y(,z)
    Hope it helps,
    Achim
        Hi all
        so far so good.
        Thanks
        Will Temperley
        grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Ah this is probably what I’m looking for, thanks Achim
Will
Hi Will,
v.net
Achim
Hi Achim
Will
2010/1/15 Achim Kisseler <ak7@jupiter.uni-freiburg.de mailto:[ak7@jupiter.uni-freiburg.de](mailto:ak7@jupiter.uni-freiburg.de)>
Hi Will,
cat|x|y|z
columns=x,y(,z)
Hope it helps,
Achim
Hi all
so far so good.
Thanks
Will Temperley
grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
have a look at 'v.build option=dump,sdump,cdump'.
there you can export the topology to stdout, etc.
it would be nice if you could write up your findings/method
into a small wiki page when you are done, there is a real lack
of PostGIS+GRASS documentation.
Hamish
2010/1/15 Hamish <hamish_b@yahoo.com>
have a look at ‘v.build option=dump,sdump,cdump’.
Hamish
Hi Hamish
Where should I write such a wiki page do you think? To be honest I’m not sure I’m using best practices - I needed a quick fix for a one-off job - I’ve been using shapefiles as an interchange medium.
I just rolled my own start/endpoint thing - it was pretty simple in Postgis to run
/* get table of unique start/endpoints */
insert into node (geom)
select st_startpoint(geom) from bound
union
select st_endpoint(geom) from bound
then
/* assign node ids to bounds */
update bound set startnode_id = (select id from node where node.geom = st_startnode(bound.geom))
Will
Hamish:
> lack of PostGIS+GRASS documentation.
http://grass.osgeo.org/wiki/PostGIS
To be honest I'm not sure I'm using best practices - I
needed a quick fix for a one-off job - I've been using
None the less, even if it is not the most efficient or elegant solution
in the world I'm of the thought that something is better than nothing,
and it might spark the basis of a more formal solution. Add editorial
comments as needed...
btw, shapefiles can be a lossy format, but I'm not sure what a better
solution would be.
union
then
thanks,
Hamish
