Well thanks all for the answers!
This is what I did:
- used r.profile to get (dist, elev) data from E-W profiles.
- I didn't considered the elipsoid, I used and approximation to a
sphere (to simplify my life :))
- from the total distance, I calculated the arc of curvature (theta)
- now I have a spreadsheet with my data (gnumeric)
- for the first point, I assigned a angular value of half the arc (theta/2)
- for each subsequent point, I subtracted the value of (theta/n) - for
n points in the profile
- then I created another column, with the "elev" value times 100 (for
vertical exaggeration) and added the radius of the Earth (6371 km)
- finally I created a polar plot of the distance and angles.
I not sure how "right" this is, but it seem to be a fair approximation.
Carlos
On Jan 15, 2008 3:30 AM, Hamish <hamish_b@yahoo.com> wrote:
Carlos wrote:
> Sorry for the OT, but can anyone point me some reference (paper, web,
> etc) that explains how can I draw a topographic profile using the
> Earth´s curvature? I am thiking about the output of r.profile (ascii,
> distance from origin + elevation), in a section of about 3000 km,
> with a vertical exaggeration of about 200 times.
maybe a little work, but consider elevation as radius perturbation and
distance along transect as theta-angle, then draw a circle with the
relief shudder in it. ie like an AM radio wave.
when that is working you can change the ideal circle to an ellipse of
appropriate bend for 3000km.
but probably it is better to just figure a way to calculate the
vertical distance between a chord connecting the two 3000km ends and
the circumference for each step along the transect.
then add that distance to the elevation.
just an idea,
Hamish
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
