I've just put the same workflow onto the wiki. I've also used r.his to make coloured shaded relief maps, and plotted them in GMT using the same method. I don't think that it is the optimal method, but at least it preserved my colour rules.
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
John
I had forgotten about r.cpt2grass; thanks for the note, Hamish.
I found a posting by Allen Cogbill on the GMT mailing list last night,
and with a lot of clunky tweaking, worked for me:
1. Convert the .tif file to a Sun Rasterfile (I use ImageMagick).
2. Use Unix tools to read the .tfw file that accompanies the .tif
file and calculate the real-world coordinate extrema.
3. Using g.region or imagemagick's identify, list the number of rows
and columns, and along with the image resolution, calculate the N-S-E-W extents.
4. Once real-world extents are known, use your psbasemap mapping scale to calculate
image width and height on paper.
5. Pass this information to psimage -W.
As long as the region defined in psbasemap's -R flag is identical to the region
of the generated tiff from GRASS, the image will plot correctly.
John, I was trying to import colored, shaded-relief tiff images using r.out.tiff.
For whatever reason, r.out.tiff always preserves my color table as opposed to r.out.gdal.
Your solution sounds a lot easier to use than mine; I'll have to try it out - thanks!
colour rules.
John
Yep. This is nealry the same general approach that I use, however- I
tend to pipe the output from r.out.bin to xyz2grd.
