[GRASS-user] OGR don't see GRASS format
Hi
when I tried to display grass vector directly on UNM maserver I found that OGR (gdal 1.3.1) don't see GRASS vector format. v.in.ogr and v.out.ogr works good, and gdal is compiled with grass suport. Gdalinfo see grass format.
ogrinfo -- formats returns:
Loaded OGR Format Drivers:
  -> "ESRI Shapefile" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "MapInfo File" (read/write)
  -> "DGN" (read/write)
  -> "VRT" (readonly)
  -> "AVCBin" (readonly)
  -> "REC" (readonly)
  -> "Memory" (read/write)
  -> "CSV" (read/write)
  -> "GML" (read/write)
  -> "ODBC" (read/write)
  -> "PostgreSQL" (read/write)
regards
Jarek
<snip>
My is:
$ ogrinfo --formats
Supported Formats:
  -> "GRASS" (readonly)
<snip>
I can't know what is wrong with your setup, but my advices are:
1. Use GDAL 1.3.2 if you can.
2. Don't build GDAL with GRASS. Build GDAL, GRASS with GDAL and then
build the GDAL-GRASS plugin (get the newest version from GDAL site).
This will save you circular dependencies. This is the recommended way
(see GRASS WIKI).
If you still have problems let us know.
Maciek
<snip>
My is:
$ ogrinfo --formats
Supported Formats:
<snip>
(see GRASS WIKI).
After compiling and installing the GRASS plugin, make sure it ended up
in the right place:
$ ls /usr/lib/gdalplugins/
gdal_GRASS.so ogr_GRASS.so
Hamish
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Jarek.
1. please use gdal 1.3.2
2. we also have problems with this, and we tracked down to a mapscript
problem:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1839
Is that your case? We're still very much interested in working on this
(we sponsored the development of ogr-grass), so please join forces with us.
All the best.
pc
Jarek Jasiewicz ha scritto:
Hi
see grass format.
-> "VRT" (readonly)
-> "REC" (readonly)
regards
Jarek
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFFKzIQ/NedwLUzIr4RAs+FAJ9Wor+qm7tW2cbga4vgFT9IlJQcqACghOoM
+tuIfW2/eKQXcXNH6V1AGmQ=
=58hX
-----END PGP SIGNATURE-----
Maciej Sieczka napisa³(a):
<snip>
My is:
$ ogrinfo --formats
Supported Formats:
<snip>
(see GRASS WIKI).
Maciek
Really, grass 1.3.2 solve problem :slight_smile: funny
shoudn't gdal 1.3.1 be depreciated???
Paolo Cavallini napisa³(a):
Hash: SHA1
Hi Jarek.
problem:
All the best.
pc
Hi
see grass format.
-> "VRT" (readonly)
-> "REC" (readonly)
regards
Jarek
Paolo Cavallini
www.faunalia.it
=58hX
grassuser mailing list
grassuser@grass.itc.it
No it was only problem with gdal, after installing 1.3.2 all works well
Regards
Karek
