[GRASS-user] Old GRASS GIS compilation
Dear all,
I am compiling GRASS 4.3 on Debian Woody.
My aim is to use r.le.dist function. I have tried to compile it but there
is one error that I can't solve. The error message is like below:
/home/firman/grass4.3src/src/libes/vask
make -f OBJ/make.rules
rm -f OBJ/V_call.o
gcc -I/home/firman/grass4.3src/src/include -DUSE_TERMIO -c V_call.c
V_call.c: In function 'V_call':
V_call.c:355: warning: comparison between pointer and integer
V_call.c: At top level:
V_call.c:430: error: static declaration of 'fmt' follows non-static
declaration
V_call.c:171: error: previous implicit declaration of 'fmt' was here
V_call.c:449: error: static declaration of 'centered' follows non-static
declaration
V_call.c:234: error: previous implicit declaration of 'centered' was here
make: *** [OBJ/V_call.o] Error 1
GISGEN failure at STEP: src/libes/vask
By this email, I would like to ask help from anyone who have experience
installing GRASS 4.3.
Thank you.
Kind regards,
Firman Hadi
Center for Remote Sensing - ITB
Jl. Ganesha No. 10, 3rd Floor
Bandung - 40132
INDONESIA
Phone: +62-22-2530701
Fax: +62-22-2530702
Website : http://crs.itb.ac.id ; www.sigro.org
Blog : http://jalmiburung.wordpress.com
rm -f OBJ/V_call.o
declaration
declaration
You can fix these specific errors by moving the definitions of fmt()
and centered() from the bottom of the file to the top.
But you may encounter many more such errors trying to compile GRASS
4.3 with a modern C compiler. You could try using an older compiler,
but that may not work with the headers from modern libraries.
> rm -f OBJ/V_call.o
> declaration
> declaration
Any reason not to use the current version of GRASS?
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
