[GRASS-user] One chamfered corner with v.buffer on an extents rectangle
I'm working in GRASS 6.4.0 and using v.buffer applied to an extents
rectangle. For some reason v.buffer is producing one chamfered corner
in the buffered vector.
The command I used was:
v.buffer -s -c --overwrite input=c83a_extents@PERMANENT
output=c83a_extents_5km_buffer@20m_DEM distance=5000.
Buffering lines...
Buffering areas...
Building topology for vector map <c83a_extents_5km_buffer>...
Registering primitives...
1 primitives registered
12 vertices registered
Number of nodes: 1
Number of primitives: 1
Number of points: 0
Number of lines: 0
Number of boundaries: 1
Number of centroids: 0
Number of areas: -
Number of isles: -
Snapping boundaries...
Breaking boundaries...
Removing duplicates...
Attaching islands...
Building areas...
1 areas built
1 isles built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Number of areas without centroid: 1
Attaching centroids...
Number of nodes: 2
Number of primitives: 2
Number of points: 0
Number of lines: 0
Number of centroids: 1
Number of areas: 1
Number of isles: 1
2 primitives registered
13 vertices registered
Building areas...
1 areas built
1 isles built
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
(Wed Apr 20 14:08:46 2011) Command finished (1 sec)
I have placed a screenshot of the outcome on the web
<http://www.nedbib.za.net/v.buffer.png&gt;\. The region was set to the DEM
raster in the background. The black triangle is the extents and the
red one the buffered polygon.
Does someone know why v.buffer would create such a chamfered corner.
I've played around with selecting different feature types and adding a
minor distance value, but I always get the same result.
Thanks
Hanlie
On Wed, Apr 20, 2011 at 2:21 PM, Hanlie Pretorius
<hanlie.pretorius@gmail.com> wrote:
The bug concerning the southwest corner is already fixed in 6.5,
awaiting ok for backport to 6.4.2.
The 3 other corners are also incorrect, I guess they should be
rounded. At least they are with other areas of similar shape.
Markus M
Buffering lines...
Buffering areas...
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Building areas...
1 areas built
1 isles built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Building areas...
1 areas built
1 isles built
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Thanks
Hanlie
grass-user mailing list
grass-user@lists.osgeo.org
Ok, thanks.
The other three corners were rounded, but I eliminated the rounding
with the -s option.
Hanlie
2011/4/20, Markus Metz <markus.metz.giswork@googlemail.com>:
Markus M
Buffering lines...
Buffering areas...
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Building areas...
1 areas built
1 isles built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Building areas...
1 areas built
1 isles built
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Thanks
Hanlie
On Wed, Apr 20, 2011 at 4:41 PM, Hanlie Pretorius
Ok, thanks.
with the -s option.
Oops, I missed that -s option. Anyway, v.buffer is not chopping off
corners also with the -s option in 6.5.
Markus M
Markus M
Buffering lines...
Buffering areas...
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Building areas...
1 areas built
1 isles built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Building areas...
1 areas built
1 isles built
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Thanks
Hanlie
If fixed, a backport would be nice (no surprise...). But I don't see it
in
http://trac.osgeo.org/grass/query?group=status&milestone=6.4.1
http://trac.osgeo.org/grass/query?group=status&milestone=6.4.2
in
Oops, I closed it without backporting to the assigned milestone which
is 6.4.1 (really). It's ticket #994.
Markus M
On Thu, Apr 21, 2011 at 4:41 PM, Markus Metz
I guess I am confused, since this changeset happened on the 6.4.svn
branch 3 months ago: http://trac.osgeo.org/grass/changeset/45198
Sorry but what is still awaiting backport to 6.4.2?
Other fixes for v.buffer2 have not been backported yet. For the module
v.buffer2, r45857, for the vector libs, r45438 and r45856 from devbr.
Done in r46079 (module) and r, 46077, r46078 (libs).
Markus M
