[GRASS-user] Opening a shape file in GRASS 6.4.3
I am new GRASS use, and learning GRASS to use conservation literacy using rare plant databases. To start with I converted a Kml file of the state of Meghalaya India to a shapefile using DNRGarmin. However when I try to open the shapefile in GRASS I keep getting errors and the map of the opened file does not look anything like the original map. What did I do wrong. I am attaching the shapefile and dbf file, I used.
thanks in advance
Sonali
This is the message I get in the command output console
Projection of input dataset and current location appear to match
Layer: Meghalay
Counting polygons for 1 features…
Importing map 1 features…
Building topology for vector map <Megh_tmp>…
Registering primitives…
1 primitives registered
258 vertices registered
Number of nodes: 2
Number of primitives: 1
Number of points: 0
Number of lines: 0
Number of boundaries: 1
Number of centroids: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Snap boundaries (threshold = 1.000e-007):
Break polygons:
Remove duplicates:
Break boundaries:
Remove duplicates:
Clean boundaries at nodes:
Merge boundaries:
Change dangles to lines:
Remove bridges:
Building areas…
2 areas built
1 isles built
Attaching islands…
Number of nodes: 9
Number of primitives: 12
Number of points: 0
Number of lines: 0
Number of boundaries: 12
Number of areas: 2
Number of isles: 1
Number of areas without centroid: 2
Find centroids for layer: Meghalay
Write centroids:
1 input polygons
Total area: 3.56766E+011 (2 areas)
Overlapping area: 0 (0 areas)
Area without category: 3.56766E+011 (2 areas)
Building topology for vector map …
3 primitives registered
17 vertices registered
Building areas…
2 areas built
1 isles built
Attaching islands…
Attaching centroids…
Number of nodes: 2
Number of primitives: 3
Number of points: 0
Number of lines: 0
Number of boundaries: 3
Number of areas: 2
Number of isles: 1
WARNING: Errors were encountered during the import
Try to import again, snapping with at least 1e-007: ‘snap=1e-007’
(Tue Aug 13 15:32:05 2013) Command finished (1 sec)
Sonali Saha, PhD.
Senior Biologist
The Institute for Regional Conservation
22601 SW 152nd Avenue
Miami FL 33170
(attachments)
Meghalay.shp (4.18 KB)
Meghalay.dbf (1.01 KB)
Meghalay.prj (414 Bytes)
Meghalay.shx (108 Bytes)
Nice!
How does the original map look like? Viewing the attached ESRI Shapefile
within from QGIS, it does not look "ok".
My guess is that either the original file has some problem (open polygon), or
the conversion did not work well.
You can try to import the KML file directly, e.g.
v.in.ogr dsn=/Path/To/Meghalay.kml out=Meghalay
Or else, convert it to anything that OGR (<http://www.gdal.org/ogr/&gt;\) supports
by using the ogr2ogr (<http://www.gdal.org/ogr2ogr.html&gt;\) utility. Or, open it
in QGIS, and save it as a Shapefile. Many options
Hope this helps, Nikos
Like Nikos, there is a problem with your file: a Geometry check report an error about an “Unclosed Ring” …
Sylvain
2013/8/13 Sonali Saha <sahairc@gmail.com>
thanks in advance
Sonali
Layer: Meghalay
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
Remove duplicates:
Break boundaries:
Remove duplicates:
Merge boundaries:
Remove bridges:
Building areas…
2 areas built
1 isles built
Attaching islands…
Number of nodes: 9
Number of points: 0
Number of lines: 0
Number of areas: 2
Number of isles: 1
Write centroids:
1 input polygons
Building areas…
2 areas built
1 isles built
Attaching islands…
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 2
Number of isles: 1
Sonali Saha, PhD.
Senior Biologist
Miami FL 33170
grass-user mailing list
grass-user@lists.osgeo.org
I tried your data with GRASS 7:
# create location from SHP file:
grass70 -c Meghalay.shp grassdata/Meghalay
# import, here the final "working" command line:
v.in.ogr Meghalay.shp out=Meghalay snap=100
Given that such "severe" snapping was needed (snapping is in map
units, here: meters), you will need to redo the conversion from KML
since the geometry in the SHAPE file is broken as the others
indicated.
I have redone the shape file, I am attching it again, and this is the error I get when I am trying to open it. The location is in india and spans two UTM zones and therefore I used lat lons
Layer: Meghalay
DBMI-DBF driver error:
ERROR: Unable to create table: ‘create table Meghalay (cat integer, TYPE varchar ( 10 ), IDENT varchar ( 24 ), LAT double precision, LONG double precision, Y_PROJ double precision, X_PROJ double precision, NEW_SEG varchar ( 10 ), DISPLAY varchar ( 10 ), COLOR varchar ( 10 ), ALTITUDE double precision, DEPTH double precision, TEMP double precision, TIME varchar ( 20 ), MODEL varchar ( 20 ), FILENAME varchar ( 254 ), LTIME varchar ( 20 ))’
(attachments)
Meghalay.shp (588 Bytes)
Meghalay.prj (145 Bytes)
thanks in advance
Sonali
Layer: Meghalay
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
Remove duplicates:
Break boundaries:
Remove duplicates:
Merge boundaries:
Remove bridges:
Building areas…
2 areas built
1 isles built
Attaching islands…
Number of nodes: 9
Number of points: 0
Number of lines: 0
Number of areas: 2
Number of isles: 1
Write centroids:
1 input polygons
Building areas…
2 areas built
1 isles built
Attaching islands…
Number of nodes: 2
Number of points: 0
Number of lines: 0
Number of areas: 2
Number of isles: 1
Sonali Saha, PhD.
Senior Biologist
Miami FL 33170
Sonali Saha, PhD.
Senior Biologist
Miami FL 33170
Layer: Meghalay
ERROR: Unable to create table: 'create table Meghalay (cat integer, TYPE varchar ( 10 ), IDENT varchar ( 24 ), LAT double precision, LONG double precision, Y_PROJ double precision, X_PROJ double precision, NEW_SEG varchar ( 10 ), DISPLAY varchar ( 10 ), COLOR varchar ( 10 ), ALTITUDE double precision, DEPTH double precision, TEMP double precision, TIME varchar ( 20 ), MODEL varchar ( 20 ), FILENAME varchar ( 254 ), LTIME varchar ( 20 ))'
perhaps TIME is a SQL reserved keyword, so you have to change that column name. (maybe TYPE too)
http://grasswiki.osgeo.org/wiki/SQL
you can use the v.in.ascii columns= option to do that. [hint: cut and paste the above as a starting point]
Hamish
