Can confirm that Grass is apparently working under 13.1. Grass crashed trying to save a screen image from the Grass toolbar command. Rebooted ok.
Thanks.
Will try and install 13.2 again and try Grass. Why was Numpy incomplete?
Kind regards
Tim
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
RG4 9RY
On 30 Nov 2014, at 05:02, grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
grass-user-request@lists.osgeo.orgYou can reach the person managing the list at
grass-user-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."Today's Topics:
1. Re: Grass 6.4, Opensuse 13.1/13.2 (Angelos Tzotsos)
2. mapping interface (shashank khare)
3. Re: how to change all cats in a vector line
(C?sar Augusto Ram?rez Franco)
4. Re: grass-user Digest, Vol 103, Issue 47 (Michael Barton)----------------------------------------------------------------------
Message: 1
Date: Sun, 30 Nov 2014 05:16:07 +0200
To: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Grass 6.4, Opensuse 13.1/13.2
Message-ID: <547A8BF7.3090306@gmail.com>
Content-Type: text/plain; charset=windows-1252; format=flowedProblem fixed on both openSUSE 13.1 and 13.2
Can you please confirm?On 11/30/2014 01:43 AM, Angelos Tzotsos wrote:
Hi Tim,
I will have a look at this and report back.
AngelosOn 11/29/2014 03:32 PM, Tim Southern wrote:
Dear all,
A couple of weeks ago I made the mistake of upgrading Opensuse on
this 32 Toshiba Laptop to 13.2. Grass failed to work with error
messages indicating NumPy had not been installed. It had been
installed but did not contain the files Grass was looking for.
Attempts at removing and re-installing NumPy all produced the same
incomplete file set. (i586 installation)I have reverted to Opensuse 13.1 and now have another non working
version Grass 6.4Traceback (most recent call
GRASS 6.4.3 (South_Oxfordshire):~ > Traceback (most recent call last):
File "/opt/grass/etc/wxpython/wxgui.py", line 139, in <module>
sys.exit(main())
File "/opt/grass/etc/wxpython/wxgui.py", line 132, in main
app = GMApp(workspaceFile)
File "/opt/grass/etc/wxpython/wxgui.py", line 45, in __init__
wx.App.__init__(self, False)
File
"/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 7981, in __init__
self._BootstrapApp()
File
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/opt/grass/etc/wxpython/wxgui.py", line 78, in OnInit
workspace = self.workspaceFile)
File "/opt/grass/etc/wxpython/lmgr/frame.py", line 111, in __init__
self.toolbars = { 'workspace' : LMWorkspaceToolbar(parent = self),
File "/opt/grass/etc/wxpython/lmgr/toolbars.py", line 40, in __init__
self.InitToolbar(self._toolbarData())
File "/opt/grass/etc/wxpython/gui_core/toolbars.py", line 96, in
InitToolbar
self.CreateTool(*tool)
File "/opt/grass/etc/wxpython/gui_core/toolbars.py", line 120, in
CreateTool
shortHelp, longHelp)
File
"/usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/wx/_controls.py",
line 3764, in AddLabelTool
shortHelp, longHelp, clientData)
File
line 3686, in DoAddTool
return _controls_.ToolBarBase_DoAddTool(*args, **kwargs)
ValueError: invalid null reference in method 'ToolBarBase_DoAddTool',
expected argument 4 of type 'wxBitmap const &'I am assuming both the errors in 13.2 and now in 13.1 are due to
installation issues. Grass 6.4 worked well in 13.1 until I
upgraded. Can anyone help?Thanks
Tim
Tim Southern
17, Park Close,
Sonning Common,
Oxfordshire
1. Re: Computing major and minor axes for polygons (Benjamin Ducke)
2. Re: Computing major and minor axes for polygons (S?ren Gebbert)
3. Re: Computing major and minor axes for polygons (Nikos
Alexandris)----------------------------------------------------------------------
Message: 1
Date: Mon, 24 Nov 2014 22:50:46 +0100
To: grass-user <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] Computing major and minor axes for polygons
Message-ID: <5473A836.5030305@fastmail.fm>
Content-Type: text/plain; charset=utf-8Right, a PCA of the polygon vertices, I assume?
Maybe "v.to.db" could be enhanced to allow it to upload
the lengths of the first two/three components to the
attribute table?For a quick fix, I solved the problem in a shell script using
a crude approximation. FWIW:
0. Set major axis length=-1
1. Rotate polygon by 10? (v.transform)
2. Fit region to polygon (g.region vect=).
3. Get width of region. If it is greater than major axis length,
set "major axis length = width"
4. Repeat from 1, until polygon has been rotated 350?
5. Minor axis length = height of current region.Like I said, it's just a crude approximation (precision can
be increased by using smaller rotation steps) and slow, too.
But it's good enough for my purposes, which is basically to
calculate "elongation=len(major)/len(min)".Best,
Ben
On 24/11/14 19:27, S?ren Gebbert wrote:
IIRC is the code to compute the major and minor axes already in GRASS.
You need to perform a Karhunen-Loewe-Transformation for each Polygon.
This is also known as principal components analysis.Best regards
SoerenAm 21.11.2014 23:33 schrieb "Benjamin Ducke" <benducke@fastmail.fm
<mailto:benducke@fastmail.fm>>:Hi All --
Does anybody here know of an existing GRASS modules that
will compute the major and minor axes for the polygons of
a vector map?Thanks and best,
Ben
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-user--
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS DeveloperSpatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org------------------------------
Message: 2
Date: Mon, 24 Nov 2014 23:44:29 +0100
To: Benjamin Ducke <benducke@fastmail.fm>
Cc: grass-user <grass-user@lists.osgeo.org>
Message-ID:
<CAPHDReJy+aLKPEZThfCd+8M935qGiLD1f-yNhrjemZ-s8RUmog@mail.gmail.com>Content-Type: text/plain; charset=UTF-8
Hi Ben,
2014-11-24 22:50 GMT+01:00 Benjamin Ducke <benducke@fastmail.fm>:
Exactly, create a covariance matrix from the vertices coordinates of
each polygon
and compute the eigenvectors and eigenvalues of these matrices.Best regards
SoerenMaybe "v.to.db" could be enhanced to allow it to upload
Ben
GRASS.
Ben
Dr. Benjamin Ducke
http://lists.osgeo.org/mailman/listinfo/grass-user------------------------------
Message: 3
Date: Tue, 25 Nov 2014 19:10:38 +0200
To: <grass-user@lists.osgeo.org>
Message-ID: <5db8e3e250d0adde57c6a9628ba5611f@nikosalexandris.net>
Content-Type: text/plain; charset=UTF-8; format=flowedOn 24.11.2014 23:50, Benjamin Ducke wrote:
5. Minor axis length = height of current region.Wow, What a smart approach!
Nikos
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 103, Issue 42
*******************************************_______________________________________________
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos------------------------------
Message: 2
Date: Sun, 30 Nov 2014 03:46:54 +0000
To: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Subject: [GRASS-user] mapping interface
Message-ID: <BLU175-W24E2D4661F9FD9E586BF7CC97C0@phx.gbl>
Content-Type: text/plain; charset="iso-8859-1"I want to develop a mapping application using python for avalanche flow simulation which takes a lot of user inputs. I do not want to go through wxGUI as the user is not interested in options shown by its GUI. Is there any documentation about 2d/3d mapping interface classes/modules which I can use. If these are not documented I can help in it.
ThanksShash
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141130/ce5cae59/attachment-0001.html>------------------------------
Message: 3
Date: Sun, 30 Nov 2014 04:13:43 +0000
From: C?sar Augusto Ram?rez Franco <caesarivs@gmail.com>
To: GRASS User List <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] how to change all cats in a vector line
Message-ID:
<CAJDYeikYbxrb3-w3ZSiiN3ufZoLzQRnQow+RjgD5=RZDs67XVw@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"Hello Michael
You could use r.stream.order after r.stream.extract to get your stream
network ordered, and then, after running r.thin on the ordered stream
network, convert it to vector using r.to.vect with the -v flag, that way,
each order is a cat, you can them use v.to.points or the add-on suggested
below to get topologically-correct points along the stream network, you
could also use r.stream.distance and upload distance and elevation to each
point using v.what.rastI usually run R from within GRASS and use the spgrass6 library to read the
vector map and analyze the data thereRegards
C?sar.
El s?b, 29 de noviembre de 2014 06:29 p.m., Helmut Kudrnovsky <hellik@web.de>
escribi?:Michael Barton wrote
Hi Markus,
What I'm trying to do is start with a raster stream map from r.drain and
convert it to a sequence of vector points, where each point has
information as to its position along the stream. I then use the pointsfor
sampling a stream profile and related information. Oddly enough, with all
of the very useful stream analysis modules, there is nothing I could find
to generate the data for a stream profile (distance from outlet or from
headwaters vs. elevation).v.to.points does a nice job of creating a sequence of evenly spaced
points
with information about their location along a line (the "along" field).
BUT, if the line is composed of multiple segments or even if it has an
irregularity in it, the "along" values start over again from 0. The only
way I can use it is if I have a very clean and continuous vector linewith
only a single cat.
This has proven surprisingly difficult to obtain reliably from my raster
stream map. So far, the only way has been to do a two sequences ofv.clean
(with thresholds 1.5 X the raster resolution) and v.build.polylines. If
you have any better suggestion, I'd love to hear it.Thanks again for the polylines idea. That was a big help.
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State Universityvoice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.eduOn Nov 29, 2014, at 10:20 AM, Michael Barton <
Michael.Barton@
> wrote:
Thanks. This helped.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.eduOn Nov 29, 2014, at 1:23 AM, Markus Neteler <
neteler@
> wrote:
On Sat, Nov 29, 2014 at 6:16 AM, Michael Barton <
Michael.Barton@
> wrote:
I have a vector line that is divided into 12 cat values. I?d like all
of the
line to have a single cat value. I?ve tried v.category to no avail. If
I
delete all categories and then add new categories, I get 12 catsagain.
And
I can find no other way to get a single cat for the entire line.
Hopefully
someone can tell what I?m missing here.Please try to use
http://grass.osgeo.org/grass70/manuals/v.build.polylines.htmlMarkus
grass-user mailing listgrass-user@.osgeo
http://grass.osgeo.org/grass71/manuals/r.stream.extract.html ?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.
nabble.com/how-to-change-all-cats-in-a-vector-line-tp5175575p5175634.html
http://lists.osgeo.org/mailman/listinfo/grass-user-------------- next part --------------
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141130/fc9f610c/attachment-0001.html>------------------------------
Message: 4
Date: Sun, 30 Nov 2014 04:51:04 +0000
To: grass-user grass-user <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] grass-user Digest, Vol 103, Issue 47
Message-ID: <D877804B-CAF8-4178-9156-6D2F160CA3C0@asu.edu>
Content-Type: text/plain; charset="utf-8"r.stream.extract can make the raster streams?ones that are pretty much equivalent to those made with r.watershed. But it can?t do stream profiles AFAICT. Also, like r.watershed, it extracts a stream network, not a particular stream. That is why we?re using r.drain to extract a particular drainage.
MICHAEL
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.eduOn Nov 29, 2014, at 4:40 PM, grass-user-request@lists.osgeo.org<mailto:grass-user-request@lists.osgeo.org> wrote:
Hi Markus,What I'm trying to do is start with a raster stream map from r.drain and
information as to its position along the stream. I then use the points for
headwaters vs. elevation).v.to.points does a nice job of creating a sequence of evenly spaced points
way I can use it is if I have a very clean and continuous vector line with
only a single cat.This has proven surprisingly difficult to obtain reliably from my raster
stream map. So far, the only way has been to do a two sequences of v.clean
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu/>On Nov 29, 2014, at 10:20 AM, Michael Barton <
Michael.Barton@
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu/>On Nov 29, 2014, at 1:23 AM, Markus Neteler <
neteler@
Michael.Barton@
of the
I
delete all categories and then add new categories, I get 12 cats again.
And
Hopefully
best regards
Helmut-------------- next part --------------
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141130/1cda7384/attachment.html>------------------------------
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 103, Issue 48
