[GRASS-user] OSGeo4 WWinGrass and msys
Hi list,
I’m using Grass 7.0.3 (64 bit) installed from OSGeo4W package. I noticed that the command line interface that winGrass uses is windowss CMD. But I’d like to be able to use some bash shell syntax, like using g.list as input to r.series. Is there a way to use MSys as the Grass 7 command line interface?
Thanks
Daniel
2016-04-05 13:43 GMT+02:00 Daniel Victoria <daniel.victoria@gmail.com>:
I'm using Grass 7.0.3 (64 bit) installed from OSGeo4W package. I noticed
that the command line interface that winGrass uses is windowss CMD. But I'd
yes, add to your apps/grass/grass7.0.3/etc/env.bat file:
set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2016-04-05 14:00 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
btw, msys package is not dependency of GRASS 7. You need to install it.
Ma
Martin Landa
2016-04-05 14:01 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
documented in r68212 [1]. Ma
[1] https://trac.osgeo.org/grass/changeset/68212
Martin Landa
Worked like a charm. Thanks Martin
On Tue, Apr 5, 2016 at 9:00 AM, Martin Landa <landa.martin@gmail.com> wrote:
Ma
Martin Landa
