from the osgeo4w-ML, please test also winGRASS6.4.3-64bit
____________________
Hi there,
I've prepared a 64bit build of major parts of OSGeo4W.
My main focus was QGIS (1.8 and master), but it also has all of it's
numerous
dependencies including current versions of GRASS 6.4 (w/o Tk), GEOS, PROJ.4,
Qt, python, GDAL (including plugins for Oracle, ECW, MrSID and FileGDB
support)
and more.
On Sun, 25. Aug 2013 at 23:40:25 +0200, Markus Neteler wrote:
Ver nice and thanks for the efforts to Juergen et al.
It seems that the 32bit OSGeo4W needs to be removed first (right?).
Right, don't mix the installs. You can install both, but not to the same
directory - new installer has also an option to specify different start menu
names so that the menu entries of multiple install don't overwrite each other.
I notice that it uses C:\Windows\system32\cmd.exe to fire up GRASS 64bit,
perhaps that's the reason?
On 64bit windows that's the 64bit cmd - the 32bit cmd is in syswow64.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
I get the same error on Windows 8 64-bit when starting grass.
I uninstalled the old osgeo4w (32bit) and removed the folder in C:\
before installing the 64-bit version.
Donovan
On Sun, Aug 25, 2013 at 2:50 PM, Jürgen E. <jef@norbit.de> wrote:
Hi Markus,
Jürgen
