[GRASS-user] Osgeo4W grass error
Hi, I’am trying to start the latest osgeo4w grass on windows 7 but I get an error when I select the dataset. Is it about the language? How can I start grass in english and not in portuguese?
Pablo.
Here is the error:
C:>“C:\OSGeo4W\apps\grass\grass-6.4.0svn”\etc\init.bat -wxpython access: Invalid argument
ERRO:LOCAÃ├O << C:\teste/ >> indisponÝvel
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 853,
in
GRASSStartUp = StartUp(0)
File “C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unicode\wx_core.p
y”, line 7935, in init
self._BootstrapApp()
y”, line 7509, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 824,
in OnInit
StartUp = GRASSStartup()
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 165,
in init
self._set_properties()
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 206,
in _set_properties
self.OnSetDatabase(None)
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 664,
in OnSetDatabase
self.OnSelectLocation(None)
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 616,
in OnSelectLocation
self.listOfLocations[self.lblocations.GetSelection()]))
File “C:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/gis_set.py”, line 584,
in UpdateMapsets
stderr=None)
File “C:\OSGeo4W\apps\grass\grass-6.4.0svn\etc\wxpython\gui_modules\gcmd.py”,
line 356, in init
_("Error: ") + self.GetError()))
line 449, in GetError
return unicode(msg, “utf-8”)
UnicodeDecodeError: ‘utf8’ codec can’t decode bytes in position 4-5: invalid dat
a
Coloque sua foto num tema anos 60, 70 e 80. Conheça o novo site de I Love Messenger.
I had just installed WinGRASS RC6 with the installer and it worked very well.
Pablo Torres Carreira
To: grass-user@lists.osgeo.org
Date: Mon, 22 Mar 2010 12:03:01 -0300
Subject: [GRASS-user] Osgeo4W grass error
Pablo.
Here is the error:
in
in OnInit
in init
in _set_properties
in OnSetDatabase
in OnSelectLocation
in UpdateMapsets
stderr=None)
line 356, in init
a
Fale com seus amigos do Messenger direto da Caixa de Entrada do Hotmail. Clique aqui
Hi Pablo,
good to hear!
Could you check if exporting a vectormap to shp works for you?
see: http://trac.osgeo.org/grass/ticket/1022
Thank you,
Milena
2010/3/22 Pablo Carreira <pablotcarreira@hotmail.com>:
well.
Milena Nowotarska
http://wiki.osgeo.org/wiki/Milena_Nowotarska
http://quantum-gis.pl/
Hi Milena,
It works,
but as reported on ticket 1022 it can’t write to c:
(it’s a windows restriction?).
look at the tests:
Test 1:
v.out.ogr input=areas_recuperacao_trabalhado@geral dsn=c:\temp\teste.shp
The map contains islands. To preserve them in the output map, use the -c flag
Vector map areas_recuperacao_trabalhado@geral is 3D. Use format specific layer creation options (parameter ‘lco’) to export in 3D rather than 2D (default)
131 centroid(s) found, but not requested to be exported. Verify ‘type’ parameter.
Exporting 564 points/lines…
484 features written
91 features without category were written
272 features without attributes were written
(Mon Mar 22 15:54:17 2010) Comando terminado (1 sec)
then I had opened the shp in qgis and the dbf in OO, everithing is ok.
Test 2:
v.out.ogr input=areas_recuperacao_trabalhado@geral dsn=c:\teste.shp
ERROR 1: Failed to create file .shp file.
ERROR 4: Failed to open Shapefile `c:\teste.shp’.
ERROR: Unable to create OGR layer
(Mon Mar 22 16:00:05 2010) Comando terminado (0 sec)
Pablo.
Hi Pablo,
good to hear!
Thank you,
Milena
2010/3/22 Pablo Carreira pablotcarreira@hotmail.com:
well.
Milena Nowotarska
Are you using Win7? I think this is a windows restriction that you
can't write to the c:\ root. This gave me a couple of headaches
also....
Daniel
On Mon, Mar 22, 2010 at 4:09 PM, Pablo Carreira
<pablotcarreira@hotmail.com> wrote:
Hi Milena,
It works,
but as reported on ticket 1022 it can't write to c:\
(it's a windows restriction?).
look at the tests:
Test 1:
flag
Vector map <areas_recuperacao_trabalhado@geral> is 3D. Use format specific
layer creation options (parameter 'lco') to export in 3D rather than 2D
(default)
131 centroid(s) found, but not requested to be exported. Verify 'type'
parameter.
Exporting 564 points/lines...
Test 2:
dsn=c:\teste.shp
ERROR 4: Failed to open Shapefile `c:\teste.shp'.
flag
(default)
Pablo.
Hi Pablo,
good to hear!
Thank you,
Milena
> well.
Milena Nowotarska
Clique aqui
grass-user mailing list
Yes, it’s Win 7.
I did some internet research and this restriction was confirmed.
Date: Mon, 22 Mar 2010 16:15:43 -0300
Subject: Re: [GRASS-user] Osgeo4W grass error
To: pablotcarreira@hotmail.com
CC: do.milenki@gmail.com; grass-user@lists.osgeo.org
can’t write to the c:\ root. This gave me a couple of headaches
also…
Daniel
pablotcarreira@hotmail.com wrote:
Hi Milena,
It works,
look at the tests:
Test 1:
flag
(default)
parameter.
Test 2:
dsn=c:\teste.shp
flag
(default)
Pablo.
Hi Pablo,
good to hear!
Thank you,
Milena
well.
Milena Nowotarska
Clique aqui
Quer falar com seus amigos do Messenger sem instalar nada? Clique aqui e veja como.
Hi Pablo,
thank you for the tests. Did you used wxpython interface for them?
for me it still looks like this:
v.out.ogr -c input=boundary_municp@PERMANENT dsn=M:/testy/test.shp
Bad file descriptor: Files
Milena
Hi Milena,
It works,
look at the tests:
Test 1:
flag
(default)
parameter.
Test 2:
dsn=c:\teste.shp
flag
(default)
Pablo.
Hi Pablo,
good to hear!
Thank you,
Milena
> well.
Milena Nowotarska
Clique aqui
Milena Nowotarska
Hi Milena,
Yes, I used wxpython WinGrass RC6 installer, not the osgeo4w version.
I’ve tried / and , with -c , without -c but I couldn’t reproduce that error.
Date: Mon, 22 Mar 2010 23:18:10 +0100
CC: grass-user@lists.osgeo.org
Hi Pablo,
Milena
Hi Milena,
It works,
look at the tests:
Test 1:
flag
(default)
parameter.
Test 2:
dsn=c:\teste.shp
flag
(default)
Pablo.
Hi Pablo,
good to hear!
Thank you,
Milena
well.
Milena Nowotarska
Clique aqui
Milena Nowotarska
Transforme-se em personagens engraçados. Conheça o novo site de I Love Messenger.
