[GRASS-user] osm data in grass
Hallo,
could someone give me a hint how to import osm data in to a grass
location.
The module v.in.osm what I download from
http://kripton.kripserver.net/software/v.in.osm/v.in.osm-2007-07-14-00
gives not a good result:
Reading from file /home/torsten/Arbeit/Gis/Daten/osm/heim.osm, writing
to map heim Reading nodes ... [ OK ] (339 nodes)
Reading segs ... [ OK ] (0 segments)
Importing way 1/77 (ID: 3213956) can't read "segcounter": no such
variable while executing
"puts -nonewline "($segcounter segments) ...""
    ("while" body line 58)
    invoked from within
"while {![eof $fchan]} {
  gets $fchan line
  if {[string match *<way\ id=* $line]} {
    incr waycount
    set list [split $line]
    foreach elem $li..."
    (file "/usr/lib/grass/scripts/v.in.osm" line 185)
Additional I do not understand what properties the target location has
to have. Do's v.in.osm transform the data into the right location e.g.:
projection: 99 (Transverse Mercator)
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5661000
south: 5660000
west: 5411000
east: 5412000
nsres: 1
ewres: 1
rows: 1000
cols: 1000
cells: 1000000
Thanks for Your help.
Torsten
Chatterreichbarkeit:
ecki@jabber.chaotic.de
AFAIK the v.in.osm is for the old API (0.4) of OSM. You can't use it
for the current data. There are utilities to import OSM data to
various formats checkout their wiki:
http://wiki.openstreetmap.org/
But if you want GIS ready data derived from OSM, you can download
shapefiles here:
http://download.geofabrik.de/
and here
http://downloads.cloudmade.com/
On Fri, Dec 12, 2008 at 5:18 AM, Torsten Eckart <torecki@arcor.de> wrote:
Hallo,
location.
   invoked from within
gets $fchan line
   incr waycount
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5661000
south: 5660000
west: 5411000
east: 5412000
nsres: 1
ewres: 1
rows: 1000
cols: 1000
cells: 1000000
Torsten
grass-user mailing list
grass-user@lists.osgeo.org
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
