[GRASS-user] Out of memory...
hello,
I didn't get any feedback and i'm posting the message again.I hope i'm not
bothering any of you but please if you have any ideas about the problem i'm
facing in v.surf.rst please let me now because i must get over it as quickly as
possibly.
So as i said before my region is :
north: 4585700
south: 4512450
west: 397250
east: 511325
nsres: 25
ewres: 25
rows: 2930
cols: 4563
Number of lines: 25180
And just before the end of the v.surf.rst calculations
i'm getting the message G realloc : out of memory and then the procedure stops
I'working on a pentium 4 cpu 3.00ghz with 2gb of ram.
Best regards
Harris
Harris,
Please see that manual page for v.surf.rst :
http://grass.itc.it/gdp/html_grass61/v.surf.rst.html
note that a segmentation algorithm is used when an extreme number of input
points are present- which by the way how many are there, and how evenly are
they distributed across your region?
Dylan
On Thursday 10 August 2006 00:35, Harris Pappas wrote:
hello,
quickly as possibly.
north: 4585700
south: 4512450
west: 397250
east: 511325
nsres: 25
ewres: 25
rows: 2930
cols: 4563
stops I'working on a pentium 4 cpu 3.00ghz with 2gb of ram.
Best regards
Harris
grassuser mailing list
grassuser@grass.itc.it
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Dylan,
Thanks for the response. The number of points of my vector file (contour lines)
is 7730470
3642623 is used by v.surf.rst.
Could you explain my about the segmax value i didn't get it much ? As for the
dmax. I've read in the manual the info about this value. As i put the
resolution (25) in g.region the value changed automaticaly. Is that ok? or
might causing problems ? For now i'm trying to see what will happen with the CV
procedure but it takes very long as expected. About the segmentation procedure
is being discribed in the manual, can i do anything about it? i guess no if i
get it right. As you can see i'm new to GRASSGIS so sorry if i make silly
questions.
Best Regards,
Harris
Harris,
I don't recommend using rst algorithm for interpolating on irregular,
sparse input as the contour lines usually are. Please browse the list
archives as this issue pops up from time to time.
For contour lines and orther clustered input datasets I personally find
natural neighbor algorithm most reliable. On Grass WIKI you'll find
r.surf.nnbathy script which is a Grass wrapper for nnbathy nat. neigh.
interp. library.
Maciek
On Thursday 10 August 2006 12:48, Harris Pappas wrote:
Dylan,
lines) is 7730470
the dmax. I've read in the manual the info about this value. As i put the
the CV procedure but it takes very long as expected. About the segmentation
procedure is being discribed in the manual, can i do anything about it? i
guess no if i get it right. As you can see i'm new to GRASSGIS so sorry if
i make silly questions.
Best Regards,
Harris
Harris,
not sure why this is running out of memory - but you might try contacting the
lead dev responsible for the RST algorithms: Helena Mitasova.
Helena Mitasova <hmitaso@unity.ncsu.edu>
good luck,
Dylan Beaudette
530.754.7341
