I have only skimmed over this briefly but IMHO the original bug report is wrong and it should be a "won't fix" - it would seem that specifying an output file is indeed optional if all that the user wants to do is list the available paper sizes.
>> I upgraded grass from cvs last night and am getting the following
>error:
>> ---<---------------cut here---------------start-------------->---
>> GRASS 6.3.cvs (locs):~ > d.m&
>> [1] 20730
>> GRASS 6.3.cvs (locs):~ > Error in startup script:
>> ERROR: Required parameter <output> not set:
>> (PostScript output file).
>> ---<---------------cut here---------------end---------------->---
Seb:
> That's because 'ps.map -p', which d.m calls from
> $GISBASE/etc/dm/print.tcl, doesn't work anymore. CCing grass-dev.
oops, sorry about that. fixed in CVS.
Also, WRT another recent change, copies= is not a cartographic mapping
instruction, so it does belong in the command line program controls.
(It does actually slightly alter the .ps output file, but my guess is
that this is such an infrequently used option that we don't have to
spend much energy on it. Anybody ever used it? For what/why?)
