[GRASS-user] Output projection questions
Hi everyone,
I am going to write a long post, just to put in context and try to explain why I am having these issues.
I am still making my first steps with 52North WPS and its GRASS backend.
I have tried the process r.loss and I receive the tiff resulting file fine, but I just realized it comes projected in EPSG:404000 (2D wildcard coordinate reference system in meters), or at least is how Geoserver interpretes it. If I try to request the layer with any other SRS openlayers does not show it, so I assume it is because of 2D wildcard projection.
My input raster map is projected in EPSG:25830 (30N UTM) so I assumed the output raster would be in the same coordinate system.
I referred to GRASS documentation and read that GRASS manage projections in a using LOCATIONS.
The tutorial [1] indicates to use the demo location under GRASS installation folder “GRASS_INSTALL_PATH/demolocation” the GRASS_INSTALL_PATH/demolocation/PERMANENT/PROJ_INFO file contains:
datum: wgs84
towgs84: 0.000,0.000,0.000
proj: ll
ellps: wgs84
I assume this is the default projection GRASS is using when invoked from WPS processes.
I tried to use another location using EPSG:25830 but still the resulting geotiff is in EPSG:404000.
To do this first I have used GRASS GUI to use the location wizard to add a new location with EPSG:25830 as default. The PROJ_INFO file under ~/grassdata/30N/PERMANENT/ looks like
name: Universal Transverse Mercator
proj: utm
datum: etrs89
ellps: grs80
zone: 30
towgs84: 0,0,0,0,0,0,0
no_defs: defined
Also added copied .grassrc70 to 30N folder and changed it contents to
GISDBASE: /home/administrador/grassdata
LOCATION_NAME: 30N
MAPSET: PERMANENT
GRASS_DB_ENCODING: utf-8
DEBUG: 0
GUI: text
Maybe I am not understanding how to work with projections…
I really hope anyone can help me out with this because I need r.los algorithm to be invoked from WPS.
Santi
