I have a vector-map with polygons and a set of points imported with v.in.ascii, both in the same location and every point is in exactly one polygon.
Both maps seem to be ok, their data can be queried.
Now I would like to know which points lie in which polygon of the vector-map.
For two vector-maps overlaying worked fine. But with the polygons and the points it does not seem to work. The maps can be overlayed but the statistics of the combined map show the attributes of the polygons and empty (though existing) columns for the attributes of the points.
THX
stn
