[GRASS-user] Overlaying vector with raster-computational problems
Dear GRASS users,
I am confronted with a “non-standard” problem and I would appreciate any help that you can give me. I have several vector files (polygons) and an arbitrary raster grid, only with category numbers associated to it. I would like to overlay the vectors onto the raster grid in order to query it and extract the categories of the raster grid which overlap with the polygons of each vector file. I am not interested in getting any info from the vector polygons, I just want know where the vector and the raster overlap. I have already thought of a way of doing this-I guess it would naturally come to mind of every GRASS user. This would involve converting the vectors into a rasters and then query the raster grid and the rasterized vectors with r.stats. This would be very easy to do, but my vectors have very small islands, which can, of course, be converted into raster cells, if I set them my region to a very fine resolution for. However, if I went down this route, this would: i) massively slow down vector to raster conversion ii) massively slow down the r.stats querying process. Just to give you an idea of the magnitude of my problem I am using several vector layers (hundreds) at global level and a raster grid at a 2 arc-minutes resolution. I am kind of stuck and I am not sure if there is any computationally efficient strategy to do what I want. Any help would be greatly appreciated!
Paolo
On 09/07/13 13:21, Paolo Ruzza wrote:
Dear GRASS users,
I am confronted with a "non-standard" problem and I would appreciate any
One possible option I see allowing you to keep your original resolution is to use v.to.points (type=boundary and dmax sufficiently small) to transform your polygon boundaries to points, then v.to.rast to transform that to raster.
Moritz
Thanks for the suggestion, but if I think that if I follow the procedure which you have indicated I will only be able to partially solve my problem. What about those parts of the polygons that are not boundaries? These might well overlap with certain cells of the raster grid…
thanks,
Paolo
2013/7/9 Moritz Lennert <mlennert@club.worldonline.be>
Dear GRASS users,
Moritz
These might well overlap with certain cells of the raster grid...
Maybe in two steps:
- First use v.to.rast to transform the polygons to raster at current resolution. This raster will have null pixels for very small islands.
- Then use the v.to.points solution to also catch those pixels with small islands.
- Then r.patch to put the two together.
Moritz
thanks,
Paolo
<mailto:mlennert@club.worldonline.be>>
        Dear GRASS users,
        appreciate any
        (polygons) and an
        it. I
        to query
        with the
        info
        guess it
        grid and
        do, but
        converted
        massively slow
        level and
        and I am
        do what I
    Moritz
Hi Paolo,
On Tuesday 09 Jul 2013 13:21:41 Paolo Ruzza wrote:
Dear GRASS users,
I'm not sure that I have understood your problem...
but maybe you can transform the raster into a vector and then check which
polygons of your vector maps are contained/overlapped in the raster area...
All the best.
Pietro
