[GRASS-user] Parallel Grass job
I’m new to GRASS. I want to parallelize a program (Grass script), but keep getting the following error.
copmpi.c:7:17: error: mpi.h: No such file or directory
copmpi.c: In function ‘main’:
copmpi.c:177: error: redeclaration of ‘row’ with no linkage
copmpi.c:45: error: previous declaration of ‘row’ was here
copmpi.c:187: error: ‘MPI_Status’ undeclared (first use in this function)
copmpi.c:187: error: (Each undeclared identifier is reported only once
copmpi.c:187: error: for each function it appears in.)
copmpi.c:187: error: expected ‘;’ before ‘status’
copmpi.c:189: error: ‘MPI_COMM_WORLD’ undeclared (first use in this function)
copmpi.c:196: error: ‘MPI_INT’ undeclared (first use in this function)
copmpi.c:211: warning: assignment makes integer from pointer without a cast
copmpi.c:212: warning: assignment makes integer from pointer without a cast
copmpi.c:218: error: ‘MPI_DOUBLE’ undeclared (first use in this function)
copmpi.c:224: error: ‘status’ undeclared (first use in this function)
copmpi.c:242: error: expected expression before ‘inrast_redchan’
copmpi.c:265: error: subscripted value is neither array nor pointer
make: *** [OBJ.x86_64-unknown-linux-gnu/copmpi.o] Error 1
tried other scripts but again
myMPIexample.c:1:69: error: mpi.h: No such file or directory
But MPI alone (mpi.h) works. and <gis.h> works alone as well too. That is no problem with libraries.
how can I solve this problem??? and what to do? help me please. Thank you !!!
From a quick look- I would say you need to install the mpi libraries and build grass with them. But I may be way off.
Stephen
On Mon 20 Feb 2012 05:26:16 AM CST, Ripsime Khachatryan wrote:
I'm new toGRASS.I want toparallelizea program (Grassscript), butkeep gettingthe following error.
triedotherscriptsbut again
ButMPIalone(mpi.h) works.and <gis.h>worksaloneas well too.That isno problemwith libraries.
how can Isolve this problem???and what to do?help meplease. Thank you !!!
grass-user mailing list
grass-user@lists.osgeo.org
Stephen Sefick
Auburn University Biological Sciences 331 Funchess Hall Auburn, Alabama 36849 **************************************************
sas0025@auburn.edu http://www.auburn.edu/~sas0025 **************************************************
Let's not spend our time and resources thinking about things that are so little or so large that all they really do for us is puff us up and make us feel like gods. We are mammals, and have not exhausted the annoying little problems of being mammals.
                                -K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
                              -Robert Gentleman
