[GRASS-user] Parallel processes
Dylan
A small sidenote on your issue. I also use GNU parallel for operations that have to run on very large scales. Never had problems with it when running it on different mapsets, i.e. I create a temporary mapset in my scripts that are wrapped by the command. Storing the data back to a main mapset or PostgreSQL allows to delete the temporary mapsets at the end of each process. Maybe a kind of hack, but works well for me. Always happy on feedback to optimize these :wink:
Greetz,
Patrick
On 20.10.2015 19:09, grass-user-request@lists.osgeo.org wrote:
Thank you Glynn, your advice confirms some empirical notes:
1. parallel processes that use data from external USB disks quickly
saturate the capacity of the bus or mechanism of the drive
2. parallel processes that use data from an internal SSD can generally
saturate all 8 cores of my Intel i7
My main motivation for asking this question was to determine instances
where parallel operations in GRASS are_not_ safe. From my reading of
the wiki, manual pages, and your recent comments on GRASS-dev, it
would appear that the following operations may not be safe:
1. region-altering
2. calculations in the presence of a MASK
3. reading "external" (r.external) GDAL sources (?)
4. some mapcalc expressions
In order to simplify my testing, I have disabled pthread support and
invoke "parallelization" via backgrounding or GNU parallel. My
examples with GNU parallel stem from the tremendous (apparent) utility
of this tool, in that most "bash for loops" can be directly converted
into "smart" parallel jobs.
Dylan
