[GRASS-user] passing output from GRASS to R.
Dear all,
I am running R inside GRASS 6.4 and I can see a list
of all my raster files when I type (from the R session)
system(“g.list rast”)
But I would like to pass the list of rasters to a vector object in R.
I tryed innocently this, but not worked:
my.rast.list<-system(“g.list rast”)
I also would like to define a pattern of raster names to the g.list command,
like only return that raster names that have “output” on the name.
By the way, I am running GRASS inside MSYS, under windows.
milton
On Mon, May 4, 2009 at 8:57 PM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Dear all,
system("g.list rast")
my.rast.list<-system("g.list rast")
Try this:
rasterfiles <- read.table(textConnection(system("g.mlist rast",intern = TRUE)))
str(rasterfiles)
'data.frame': 42 obs. of 1 variable:
$ V1: Factor w/ 42 levels "aspect","basin_50K",..: 31 1 2 3 4 5 6 7 8 9 ...
rasterfiles
                     V1
1 myfacility
2 aspect
3 basin_50K
4 boundary_county_500m
like only return that raster names that have "_output_" on the name.
So:
rasterfiles <- read.table(textConnection(system("g.mlist rast pattern="*_output_*",intern = TRUE)))
str(rasterfiles)
Please report if above works (as it does on Linux).
Hi Markus,
Under windows I needed only small changes
rasterfiles ← read.table(textConnection(system(“g.mlist.exe rast pattern=output”, intern = TRUE)))
Thanks a lot,
milton
2009/5/4 Markus Neteler <neteler@osgeo.org>
Dear all,
Try this:
rasterfiles ← read.table(textConnection(system(“g.mlist rast”,intern = TRUE)))
str(rasterfiles)
‘data.frame’: 42 obs. of 1 variable:
$ V1: Factor w/ 42 levels “aspect”,“basin_50K”,…: 31 1 2 3 4 5 6 7 8 9 …
rasterfiles
V1
1 myfacility
2 aspect
3 basin_50K
So:
rasterfiles ← read.table(textConnection(system("g.mlist rast pattern=“output”,intern = TRUE)))
str(rasterfiles)
From spgrass6 0.6-*, and after installing the R XML package (off CRAN but
installs automatically from Prof. Ripley's extra Windows repository if you
are on Windows), you can use:
rasterfiles <- execGRASS("g.mlist", parameters=list(type="rast",
pattern="*ele*"), intern=TRUE)
(here from spearfish, which has *ele* rasters in PERMANENT). Do:
parseGRASS("g.mlist")
to see the flags and parameters. As Markus pointed out, intern=TRUE is the
key argument, to get the output of the GRASS command back into the R
workspace. There are issues with regard to quoting between platforms for a
few GRASS commands, but most things now work. I tried this on MSYS Windows
native 6.4.0 RC4.
Roger
Milton Cezar Ribeiro wrote:
Hi Markus,
rasterfiles <- read.table(textConnection(system("g.mlist.exe rast
pattern=*output*", intern = TRUE)))
Thanks a lot,
milton
> Dear all,
Try this:
TRUE)))
> str(rasterfiles)
> rasterfiles
                    V1
1 myfacility
2 aspect
3 basin_50K
command,
So:
> str(rasterfiles)
grass-user mailing list
grass-user@lists.osgeo.org
Roger Bivand
Economic Geography Section
Department of Economics
Norwegian School of Economics and Business Administration
Helleveien 30
N-5045 Bergen, Norway
View this message in context: http://n2.nabble.com/passing-output-from-GRASS-to-R.-tp2788835p2791576.html
Thanks for both, Markus and Roger Bivand.
milton
2009/5/5 Roger Bivand <Roger.Bivand@nhh.no>
installs automatically from Prof. Ripley’s extra Windows repository if you
rasterfiles ← execGRASS(“g.mlist”, parameters=list(type=“rast”,
pattern=“ele”), intern=TRUE)
(here from spearfish, which has ele rasters in PERMANENT). Do:
parseGRASS(“g.mlist”)
native 6.4.0 RC4.
Roger
Hi Markus,
Thanks a lot,
milton
Dear all,
Try this:
TRUE)))
str(rasterfiles)
rasterfiles
V1
1 myfacility
2 aspect
3 basin_50K
command,
So:
str(rasterfiles)
Roger Bivand
Helleveien 30
