I am building a simulation python code that read a raster maps on grass mapset.
As my maps is not so large (512x512 pixels) I dump it on a text file
(using r.out.ascii), after I read the text file on python, parse it using a function that
I wrote, and after create a matrix-like object on Python.
I would like to know if I can read my raster map on python wihout
save it on external text file. Case yes, a short example are welcome.
on a text file
you might look at NumPy http://numpy.scipy.org/ + NumPtr python
extension. NumPtr can be found in the swig/python/ dir in the grass
source code. (also examples/m.distance + rasteraccess.py there)
NumPy is also used by the wxGUI profile tool.
SciPy is another thing to check out.
please post back to the list with what you learn & if you succeed
maybe add a page to the grass wiki with steps?
on a text file
