[GRASS-user] patching dems together
r.patch this gives me single color when the original dems where
reliefs (there is topography). What am I doing wrong? I have set the
n-s e-w resolution to 00:00:03 because I downloaded 1/3 arc second dem
from the seamless server (.adf). I am confused as to what to do next.
Is r.patch the wrong thing to be doing?
thanks in advance
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
                -K. Mullis
thanks in advance
some ideas:
* check range of values with "r.info YourDEMtile(s) -tr" before patching
* set g.region rast=`g.mlist rast=PatternThatMatchesDEMtiles sep=,`
res=WantedResolution
* r.patch input=... out=patchedDEM
* check range again "r.info -tr patchedDEM"
* r.colors patchedDEM color=terrain
* d.rast
Somewhere in between you should find the "problem" if there is any.
Kind regards, Nikos
Try r.colors for setting a new color table (e.g. elevation).
Moritz
values range from ~-9 to ~800 there is a tile which has no elevation.
The patched dem only ranges from 0-296. This may be the problem.
On Thu, Jul 9, 2009 at 11:27 AM, Moritz
Moritz
Stephen Sefick
                -K. Mullis
It seems that the current computational region did not include all tiles.
Try setting the computational region to include all tiles with g.region
rast=<all your tiles>.
Check the resolution of each tile with r.info -s. If they are not all
the same, use the coarsest resolution to be safe.
Check the resolution of the computational region. It must be the same
like the coarsest resolution, if not, set it to that.
Set the same color rules for all tiles. Use srtm or etopo2 but not
elevation because elevation will be different for each tile.
Display all tiles, zoom to the computational region.
Patch all tiles.
Set the same color rules to the patched DEM like to the tiles.
Add the patched DEM to the display, it should look like the previous
display with all the tiles.
Good luck,
Markus M
I followed the directions all set to srtm, computation region set to
resolution of the coarsest (they are all the same and 00:00:01). The
map is still coming out as 7 different solid color blocks.
On Thu, Jul 9, 2009 at 12:58 PM, Markus
Patch all tiles.
Good luck,
Markus M
Stephen Sefick
                -K. Mullis
You have set the region to include all tiles? You have zoomed to the
current region? The patched DEM still ranges from 0-296 only and not
from 9-800 (r.info -r)?
I've done that regularly with SRTM tiles and it worked, no problems
(6.4.0RC5).
Patch all tiles.
Good luck,
Markus M
yes still 0-296. I think the problem is this
r.info -s series_map
nsres=1:09:25.8
ewres=1:01:15.8736
however:
g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: nad83
ellipsoid: grs80
north: 34:23:38.999997N
south: 30:23:31.999996N
west: 84:31:21.99999W
east: 79:25:00.999989W
nsres: 0:00:01
ewres: 0:00:01
rows: 14407
cols: 18381
cells: 264815067
any ideas,
Stephen
On Thu, Jul 9, 2009 at 1:50 PM, Markus
(6.4.0RC5).
Patch all tiles.
Good luck,
Markus M
Stephen Sefick
                -K. Mullis
nsres=1:09:25.8
ewres=1:01:15.8736
however:
g.region -p
zone: 0
datum: nad83
ellipsoid: grs80
nsres: 0:00:01
ewres: 0:00:01
rows: 14407
cols: 18381
cells: 264815067
Hmm, doesn't make sense if you have set this region before patching. I
guess now you must post the exact commands you used in the exact order
you used them, plus grass version and operating system (wasn't it 3.0 on
Linux?).
Markus M
any ideas,
Stephen
(6.4.0RC5).
Patch all tiles.
Good luck,
Markus M
Markus,
I made a Permanent Map set and put in everything from the projection
region, and followed your directions. They worked. I have created
the map, and I am now reprojecting it into another mapset so that I
can use v.strahler to calculate stream orders. Thank you so much for
your help. As it is most of the time- I think it was operator error.
Sorry, for the headache.
Stephen Sefick
On Thu, Jul 9, 2009 at 2:55 PM, Markus
nsres=1:09:25.8
ewres=1:01:15.8736
however:
g.region -p
zone: 0
datum: nad83
ellipsoid: grs80
nsres: 0:00:01
ewres: 0:00:01
rows: 14407
cols: 18381
cells: 264815067
Linux?).
Markus M
any ideas,
Stephen
(6.4.0RC5).
Patch all tiles.
Good luck,
Markus M
Stephen Sefick
                -K. Mullis
