Dear GRASS List,
I'm trying to do something in GRASS and can't figure out an efficient way to do it. I'm guessing it is possible with 1-3 lines, but don't know which ones. The algorithm I'm developing would be much more complex, and I hope someone can suggest a shortcut.
I have several satellite products of the same region each day. For simplicity sake lets assume 3 overlapping solar zenith angle (SZA) products, and for each of those a visual image (VIS). I'd like to have one visual raster that, for each pixel, has the minimum SZA.
I can get the minimum SZA for each pixel with
r.mapcalc "SZA_min = min(SZA1,SZA2,SZA3)"
But now I've lost the source of the minimum SZA, and I need it to link SZA1 with VIS1.
I could encode categories for each SZA:
r.category map=SZA1 cats=0-360 values=1
r.category map=SZA2 cats=0-360 values=2
r.category map=SZA3 cats=0-360 values=3
And then
r.mapcalc "SZA_min_cat = min(@SZA1,@SZA2,@SZA3)"
And then use SZA_min_cat (values: 1 to 3) as a lookup to VIS1,VIS2,VIS3. I'm actually not clear how to do this last step, if this is the correct approach. Do I return to r.mapcalc, or is r.univar the right tool?
Any help will be much appreciated.
-k.
Le 17 octobre 2017 13:38:34 GMT+02:00, Ken Mankoff <mankoff@gmail.com> a écrit :
Dear GRASS List,
SZA1 with VIS1.
And then
the right tool?
Check r.series, notably the min_raster method.
Moritz
-k.
grass-user mailing list
grass-user@lists.osgeo.org
Thanks. That helps. I now use the output of that (SZA_lut) and the following:
r.mapcalc --o <<EOF
eval(SZA0 = if(SZA_lut == 0, ${img_arr[0]}),
SZA1 = if(SZA_lut == 1, ${img_arr[1]}),
SZA2 = if(SZA_lut == 2, ${img_arr[2]}),
SZA3 = if(SZA_lut == 3, ${img_arr[3]}),
SZA4 = if(SZA_lut == 4, ${img_arr[4]}),
SZA5 = if(SZA_lut == 5, ${img_arr[5]}))
SZA_min = SZA0+SZA1+SZA2+SZA3+SZA4+SZA5
EOF
-k.
On Tue, Oct 17, 2017 at 1:41 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Dear GRASS List,
I’m trying to do something in GRASS and can’t figure out an efficient
way to do it. I’m guessing it is possible with 1-3 lines, but don’t
know which ones. The algorithm I’m developing would be much more
products, and for each of those a visual image (VIS). I’d like to have
r.mapcalc “SZA_min = min(SZA1,SZA2,SZA3)”
But now I’ve lost the source of the minimum SZA, and I need it to link
SZA1 with VIS1.
And then
r.mapcalc “SZA_min_cat = min(@SZA1,@SZA2,@SZA3)”
VIS1,VIS2,VIS3. I’m actually not clear how to do this last step, if
the right tool?
Moritz
-k.
