Hello , nice to say hello , I have 2 raster : A raster is 20 meters and another 30 meters in the same area. As I can do in QGIS for a resampling an image with reference to the other? and that the pixels are perfectly aligned ? I use a google translator ! Thank you very much Eddison
Eddison,
First align your region to the destination raster with 'g.region
raster=rastername'.
Then resample the other raster.
Laurent
2016-08-02 11:48 GMT-05:00 Eddison Araya <eddisonjose@gmail.com>:
? I use a google translator ! Thank you very much Eddison_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
Hello thank you very much , you can put some screenshots of the process? Greetings and thanks Eddison
2016-08-02 11:13 GMT-06:00 Laurent C. <lrntct@gmail.com>:
Eddison,
First align your region to the destination raster with ‘g.region
raster=rastername’.
Then resample the other raster.Laurent
have a look at https://grass.osgeo.org/grass70/manuals/g.region.html
-a Align region to resolution
raster=name[,name,...] Set region to match raster map(s)
g.region -a raster=your_raster_you_want_align_to
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Perform-resample-a-raster-using-another-image-as-a-reference-for-the-process-tp5279137p5279159.html
* Helmut Kudrnovsky <hellik@web.de> [2016-08-02 12:21:17 -0700]:
-a Align region to resolution raster=name[,name,...]
Also useful (to read and use): https://grass.osgeo.org/grass70/manuals/r.resample.html
Nikos
On Wed, Aug 3, 2016 at 12:44 AM, Nikos Alexandris
See also
https://grasswiki.osgeo.org/wiki/Computational_region
g.region -a raster=your_raster_you_want_align_toAlso useful (to read and use):
For an overview, see also
https://grasswiki.osgeo.org/wiki/Interpolation
PS: I have now added the second link to all relevant manual pages
Hello thank you very much , then the command is as follows:
g.region -a -p raster=lsat5_1987_10 align=urban ?
regards
Eddison
2016-08-03 5:52 GMT-06:00 Markus Neteler <neteler@osgeo.org>:
- Helmut Kudrnovsky <hellik@web.de> [2016-08-02 12:21:17 -0700]:
-a Align region to resolution raster=name[,name,…]See also
https://grasswiki.osgeo.org/wiki/Computational_regionSet region to match raster map(s)
https://grass.osgeo.org/grass70/manuals/r.resample.htmlFor an overview, see also
https://grasswiki.osgeo.org/wiki/InterpolationMarkus
>>> process?
Helmut Kudrnovsky:
See also
Nikos Alexandris:
Markus Neteler:
Eddison Araya:
Eddison, the command is as Helmut proposed in one of his first posts
(see below).
Essentialy, you want to set the extent of the region (within which
grass' raster modules will operate) to match a raster map's dimensions.
That is,
g.region raster=Your_Raster_Map
And, even more, you want to force the alignment of the extent to this
map. This is done by addin the -a flag:
g.region -a raster=Your_Raster_Map
That's it, nothing more.
Nikos
ps- Please, if you would like, keep bottom posting so as to to preserve flow of the
discussion.
>>> process?Helmut Kudrnovsky:
>> -a Align region to resolution raster=name[,name,...]See also
https://grasswiki.osgeo.org/wiki/Computational_region>> Set region to match raster map(s)
>> g.region -a raster=your_raster_you_want_align_toNikos Alexandris:
> https://grass.osgeo.org/grass70/manuals/r.resample.htmlMarkus Neteler:
https://grasswiki.osgeo.org/wiki/InterpolationPS: I have now added the second link to all relevant manual pages
Eddison Araya:
g.region -a -p raster=lsat5_1987_10 align=urban ?Eddison, the command is as Helmut proposed in one of his first posts
(see below).Essentialy, you want to set the extent of the region (within which
grass' raster modules will operate) to match a raster map's dimensions.That is,
map. This is done by addin the -a flag:g.region -a raster=Your_Raster_Map
Eddison, seems I was to fast (and writing out of memory) and your above
command is correct, I guess. The -a will align the region's extent, to,
well, as the manual explains, the resolution.
So, you'd need your `align=` part.
Nikos
2016-08-03 15:17 GMT-06:00 Nikos Alexandris <nik@nikosalexandris.net>:
>>> process?
Helmut Kudrnovsky:
See also
Nikos Alexandris:
Markus Neteler:
Eddison Araya:
well, as the manual explains, the resolution.So, you'd need your `align=` part.
Nikos
Hello, thank you very much to all of you for your answers, for their
willingness to cooperate , very friendly. regards Eddison
