I run Ubuntu gutsy.
I just play around with data on my own machine... copied from one folder
to another.
if data was copied from a CD make sure that the GRASS database,
locations, etc. have been given back write permissions, recursively.
(the filesystem cares)
I dit that.
also check that the current user owns the mapset you are trying to
load. (by default GRASS lets you read from anyone mapset but only you
can write to your own)
But,
what if I want to start from the scratch? I am trying to create a new
empty directory and grant rwx access. And then create with the GUI a new
LOCATION. It only works when I use the text mode.
for the file system test try going to where you are trying to make the
new location and create a new directory, files, etc.
No problems to create folders as "nik"
That is all GRASS
is trying to do and if you can do that as a normal user, and the same
user as starts grass6, GRASS should be able to it as well.
I think there something wrong with... ? Why grass (grass62) is
problematic but grass63 (the compiled from source bin) does its job
without hanging anywhere(?)
Also follow up that x-terminal-emulator error. Is this Ubuntu or
Debian?
What version(s) of OS & GRASS?
ls -l /usr/bin/x-terminal-emulator
lrwxrwxrwx 1 root root 37 2008-02-06 04:42 /usr/bin/x-terminal-emulator
-> /etc/alternatives/x-terminal-emulator
ls -l /etc/alternatives/x-terminal-emulator
lrwxrwxrwx 1 root root 31 2008-02-06
04:42 /etc/alternatives/x-terminal-emulator
-> /usr/bin/gnome-terminal.wrapper
Hamish
Thanks for the detailed mail.
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
