Hi all
I’m thinking if there is a way to project a series of points into a line, but this projection must be in a direction perpendicular to the line.
Tks
Carlos Grohmann
Sent with Sparrow
Hi all
Tks
Carlos Grohmann
Sent with Sparrow
Hi all
One approach is a three step process:
1- Begin with v.distance from your points to the line. The ‘output’ parameter will be a line vector of the (perpendicular) connectors from the points to the line.
2- Next do v.patch to merge the connectors to the line.
3- And finally v.clean with tool=break error=connector_points. The ‘error’ parameter contains all those points where a new intersection had to be created after patching the connectors to the line vector.
(There is a chance that one connector will intersect the line exactly on a node, and then v.clean won’t find that point since it’s not an ‘error’. But that’s probably a very rare case.)
HTH,
Micha
Micha Silver
GIS Consultant, Arava Development Co.
[http://www.surfaces.co.il](http://www.surfaces.co.il)
Thanks Micha. I though of v.distance but I wasn’t sure if the connectors would be perpendicular
Carlos Grohmann
Sent with Sparrow
On Thursday, 10 de May de 2012 at 14:42, Micha Silver wrote:
On 05/10/2012 06:31 PM, Carlos Grohmann wrote:
Hi all
I’m thinking if there is a way to project a series of points into a line, but this projection must be in a direction perpendicular to the line.One approach is a three step process:
3- And finally v.clean with tool=break error=connector_points. The ‘error’ parameter contains all those points where a new intersection had to be created after patching the connectors to the line vector.(There is a chance that one connector will intersect the line exactly on a node, and then v.clean won’t find that point since it’s not an ‘error’. But that’s probably a very rare case.)
HTH,
MichaTks
Carlos GrohmannSent with Sparrow
This mail was received via Mail-SeCure System.
_______________________________________________ grass-user mailing list [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) [http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user) This mail was received via Mail-SeCure System.
-- Micha Silver GIS Consultant, Arava Development Co. [http://www.surfaces.co.il](http://www.surfaces.co.il)
Oops, of course that the shortest distance will be perpendicular. I should do one thing at a time… trying to code while in a field trip in the Amazon is not the best idea…
Carlos Grohmann
Sent with Sparrow
Hi all
HTH,
MichaTks
v.profile is designed to do exactly what You are looking for.
http://grass.osgeo.org/wiki/GRASS_AddOns#v.profile
Maris.
2012/5/10 Carlos Grohmann <carlos.grohmann@gmail.com>:
Hi all
I'm thinking if there is a way to project a series of points into a line,
but this projection must be in a direction perpendicular to the line.Tks
Carlos Grohmann
Sent with Sparrow_______________________________________________
Maris,
many many thanks.
Carlos
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
Can’t stop the signal.
Sent with Sparrow
Maris.
Hi all
Carlos Grohmann
Sent with Sparrow
Hi Professor Carlos,
Please take a look here: http://profmarcello.blogspot.com.br/2012/02/grass-snapping-points-to-lines.html
Marcello Benigno B. de Barros Filho
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://about.me/marcello.benigno
Nice solution. You could probably simplify a bit more by using v.in.db instead of v.out.ascii/v.in.ascii.
Moritz
