Dear all,
does someone know if there's a simple way to create perpendicolar
segments to a lines (equispaced along this line)???
like this...
I have had a look to v.lrs.XXX but I have got some problems to
understand the needed parameters.. also looking at the papers from Radim
didn't help me...
what I need is probably a simple tutorial or something similar...
I mean.. if someone can help me with this topic I can write a wiki page
on this...
but at the moment I can't understand wich can be the simpler way to
solve this problem...
v.segment?
v.split?
v.to.points?
v.lrs.XXX?
I'am quite confused!!!
thank you
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
jabber: geoivan73@jabber.org
Dear all,
like this...
How about this:
0. Make sure you input line has categories.
1. Create close parallel lines on the sides of your input line (choose
the distance that suits you):
v.parallel input=center_line output=left distance=0.00001
v.parallel input=center_line output=right distance=-0.00001
2. Calculate the offsets as needed, then use them to create points on
desired locations, along the lines on the 2 sides of your input line:
cat offsets | v.segment input=right output=right_seg
cat offsets | v.segment input=left output=left_seg
Dear all,
like this...
Radim didn't help me...
page on this...
v.segment?
v.split?
v.to.points?
v.lrs.XXX?
m.cogo might help as part of a script,
Description:
A simple utility for converting bearing and distance measurements to
coordinates and vice versa. It assumes a cartesian coordinate system
