[GRASS-user] PLEASE HELP!
From what I can see of GRASS-user postings, most of the discussion is about quite technical aspects of GRASS.
Please can someone address my very basic problems?
1 – after running GRASS for about half an hour, the layer selection becomes unresponsive.
2 – I get wired interaction between layers, with activating some switching off the display of others. It is not a masking issue, because selecting and deselecting some layers will make them display properly (but sometimes causes others to disappear).
I suspect I may be exceeding a limit on the number of columns or layers, but I have no idea how to check this.
I am becoming desparate.
Regards
Neil
Neil Wyatt
You have probably a lot of layers in Layer Manager, if you don't need them
all, you can right click on the layer and remove, or you can uncheck it. If
you have checked a lot of layers, the rendering becomes slow.
I fixed (hopefully) this weird behavior a couple of weeks ago. So either
you can update to a newer version of grass or, as a workaround, it should
be enough to make the Layer Manager window larger (vertically), so that you
can see all the layers without scrolling.
Regards
Neil
Neil Wyatt
grass-user mailing list
grass-user@lists.osgeo.org
