[GRASS-user] Plot 3D Drillholes in Grass GIS
I was wondering if anybody is familiar with ways of plotting drill hole data in Grass (i.e. to visualize in NVIZ or to manage attributes, query etc...) based on point features with known dip, strike and azimuth angles.
I have come across a paper (Development of Visualization Tools for Geologic Information on Grass GIS) which seems to do just that, however as far as I can tell it has not been released or provided to the Grass Community.
If anybody is familiar with anything else, it would be greatly appreciated.
Casey
Hi...
we have worked on doing volumetric interpolation of dip and direction
obtained from survey of geological strata (but if you have a lot of data
coming from more drill holes the problem is exactly the same:
1) we consider the normal to the plane representing in each point the
badding strata
2) we interpolate (3d interpolation with v.vol.rst) the three components
(xyz) of this normal, obtaining a voxel map for each component
3) we combine back this three components to obtain a volumetric
interpolated map (voxel) of geological dip and direction
4) now we can obtaine slices of this two maps....
but if your problem is simply visualization of the data coming from a
single hole then a possible solution is to create inclined planes
(small) that pass from the point where bedding has been collected.
Then represents this planes into NVIZ
cheers
ivan
Community.
Casey
grass-user mailing list
grass-user@lists.osgeo.org
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
Hi Casey,
You can take a look at
"Construction and Visualization of a Three Dimensional Geologic Model Using GRASS GIS"
Transactions in GIS Volume 8 Issue 2, Pages 211 - 223
http://www3.interscience.wiley.com/cgi-bin/fulltext/118806744/PDFSTART
"Development of Visualization Tools for Geologic Information on Grass GIS" is available at
http://wgrass.media.osaka-cu.ac.jp/gisideas06/viewpaper.php?id=170
The corresponding author of the above paper are preparing to publish a detailed paper on the above work and will release to the GRASS community. Not sure how soon.
Best regards
Venka
Thanks for your reply to my question Ivan and Venka (and thanks for the links
to the papers). If you get word on when the corresponding author is planning
on releasing the above work to the grass community I would be very
interested in hearing about it.
Casey
Venkatesh Raghavan wrote:
Hi Casey,
Using GRASS GIS"
angles.
Community.
Best regards
Venka
View this message in context: http://n2.nabble.com/Plot-3D-Drillholes-in-Grass-GIS-tp2457531p2470485.html
Casey,
I was very interested in your original email, so I tried to track down the GRASS modules mentioned in the paper you cited. As it turns out the authors have written several related papers. While I was able to obtain the other papers, I could not locate the software. So, I emailed the authors (Shinji Masumoto) and just got a response. Unfortunately, the authors are unwilling to release the software into the public domain. I have not specifically tried NVIZ visualization as you describe, but I think the 3rd Ed. of "Open Source GIS: A GRASS GIS Approach" covers how to create 3D vectors which can be brought into NVIZ to produce what you need.
Tom
Casey
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
I was trying to find related software or a way to work with boreholes
and geological cross sections in grass, not just for the drawing part
but a way to use it for geological analysis.
It's very sad the fact that these modules are not for public use, even
with a stricter licensing than GPL.
Vasilis
On Wed, Mar 18, 2009 at 1:45 PM, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
Casey,
Tom
Community.
appreciated.
Casey
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
