I have received from somebody a list of quarter degree squares located in South Africa. Is there
any easy way of plotting these into a map together with the borders of South Africa and the
provinces? The second part (the borders) should not be the problem, but how can I convert the list
of qds into a raster / point layer?
On Wed, Sep 19, 2012 at 12:20 PM, Rainer M Krug <r.m.krug@gmail.com> wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Africa. Is there any easy way of plotting these into a map together with the borders
of South Africa and the provinces?
If I got it right, you could look into r.in.srtm script. A SRTM tile position
is derived from the *name* of the tile.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi
there any easy way of plotting these into a map together with the borders of South Africa and
the provinces?
If I got it right, you could look into r.in.srtm script. A SRTM tile position is derived from
Thanks.
In the manual of r.in.srtm, it says "SRTM tiles are of 1 degree by 1 degree size.", but my
references refer to quarter degree squares - can I use this as well? Could I get some guidance how?
The list looks as follow:
3030CC
3129BB
3129BD
3129DA
3130AA
3218DB
3318BC
3318CB
And no, I don't think there is the option to get a different format - closed source software,
custom build, and developer left....... No Comment.
Thanks - but I have a few blocks more. Where can I download the whole map of the qds? I am
browsing through NGI.gov.za at the moment, but can't find it - if the map is in vector format, one
polygon per qds, I could digitize the qds I have - they are not that many (but more then in the
email). Did you do the shp file manually or automatic?
Rainer
and the provinces? The second part (the borders) should not be the problem, but how can I
convert the list of qds into a raster / point layer?
