[GRASS-user] Point count with large vectors
I'm not sure if this has been solved before.
I have two large points files (>20,000 sites), and I want to find the number of
points in A falling within a given distance of the points in B. So the desired
output would be:
Cat Point count from B
1 10
2 3
3 12
...etc
I can use a buffer from Map A and run v.distance, but it takes an extremely long
time, so suggestions would be welcome!
Richard
On 09/05/09 00:51, Richard Chirgwin wrote:
output would be:
1 10
2 3
3 12
...etc
Don't know if this would be much faster (what takes a long time in your approach ?), but you could use only v.distance to create a distance matrix (-a), and setting the threshold dmax to your distance.
Then a simple aggregate query on the reulting table should give you what you need.
Moritz
number of
desired
output would be:
1 10
2 3
3 12
...etc
extremely long
you need.
As to "a long time", I left one loop running for several days and only completed
one state of Australia!
And now an embarrassing admission, in spite of using v.distance *lots*, I never
saw the -a flag before. Many thanks, Moritz!
Richard
Moritz
