I wish to convert point data (say with attribute 'A' having value
between 0 - 100), in to thematic map, showing area divided into four
region as:
Region I : Value of A between 0-25
Region II : Value of A between 25-50
Region III: Value of A between 50-75
Region IV: Value of A between 75-100
What command or sequence of command I need to use. Any pointer to
document / tutorial will be appreciated.
H.S.Rai
region as:
I think that v.reclass does what you want.
Two ways to do this (see the man page)
- You’ll need to first create a reclass file that looks like:
cat 1
where A <= 25
cat 2
where A>25 and A<=50
then run
v.reclass in=point_vect out=point_reclass rule=reclass_file
Note that in the new vector you’ll loose any attributes from the original point data.
- Alternatively you could add an additional column in the original vector and populate it with values based on A, as so:
v.db.addcol points column=“label varchar(12)”
v.db.update points col=label val=‘Region I’ where=‘A<=25’
v.db.update points col=label val=‘Region II’ where=‘A>25 and A<=50’
and now do the v.reclass step but use the parameter ‘column=label’ to create a new reclassed vector based on those labels
Micha
