[GRASS-user] point reprojection: v.proj vs cs2cs results
Dear Users,
I need to reproject a point (280799|4802457) from location A to location
B
these are the PROJ_INFO files:
_______________________
LOCATION A (UTM ED50)
datum: eur50
towgs84: -87.000,-98.000,-121.000
proj: utm
ellps: international
a: 6378388.0000000000
es: 0.0067226700
f: 297.0000000000
zone: 33
and
Location B (Gauss-Boaga EST Rome40)
datum: rome40
towgs84: -104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
proj: tmerc
es: 0.0067226700
f: 297.0000000000
lat_0: 0.0000000000
lon_0: 15.0000000000
k_0: 0.9996000000
x_0: 2520000.0000000000
y_0: 0.0000000000
__________________
if I try to use v.proj for the point, from location A to Location B,
I obtain this coordinate (into location B):
2300732.60711273|4802279.27423501
Instead, if I use cs2cs:
echo "280799 4802457 263" | cs2cs -v +init=epsg:23033 +to +proj=latlong
+datum=WGS84 |cs2cs -v +proj=latlong +datum=WGS84 +to +init=epsg:3004
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
(where:
cat /usr/share/proj/epsg | grep Italy -A1 | grep "zone 2" -A1
# Monte Mario / Italy zone 2
<3004> +proj=tmerc +lat_0=0 +lon_0=15 +k=0.999600 +x_0=2520000 +y_0=0
+ellps=intl +units=m +no_defs <>
and
cat /usr/share/proj/epsg | grep UTM -A1 | grep ED50 -A1 |grep 33 -A1
# ED50 / UTM zone 33N
<23033> +proj=utm +zone=33 +ellps=intl +units=m +no_defs <>
I obtain this output:
# ---- From Coordinate System ----
#Lat/long (Geodetic)
# +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
# ---- To Coordinate System ----
#Transverse Mercator
# Cyl, Sph&Ell
# +init=epsg:3004 +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
# +proj=tmerc +lat_0=0 +lon_0=15 +k=0.999600 +x_0=2520000 +y_0=0
+ellps=intl
# +units=m +no_defs
#Universal Transverse Mercator (UTM)
# Cyl, Sph
# zone= south
# +init=epsg:23033 +proj=utm +zone=33 +ellps=intl +units=m +no_defs
2300810.30 4802292.11 425.44
As you can see the resulted coordinate is quite different from the
previous one...
can someone explain me this strange result???
surely it is my fault, but I can't understand where I'm wrong
Thanks
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
jabber: geoivan73@jabber.org
ivan marchesini napisa³(a):
Dear Users,
B
datum: eur50
proj: utm
es: 0.0067226700
f: 297.0000000000
zone: 33
and
datum: rome40
proj: tmerc
es: 0.0067226700
f: 297.0000000000
lat_0: 0.0000000000
k_0: 0.9996000000
y_0: 0.0000000000
__________________
Correct cs2cs syntax would be:
$ echo "280799 4802457 263" | cs2cs +init=epsg:23033
+towgs84=-87.000,-98.000,-121.000 +to +init=epsg:3004
which gives:
2300732.61 4802279.28 265.39
OK?
Maciek
Dear Maciej,
thanks a lot...
yes, effectivelly I have forgotten to use the datum transformation
parameters for UTM-ED50...
but today I have also learn, from you, that I can use cs2cs directly
from a projected system to another projected one, without passing from a
latlong system...
many, many thanks...
Ivan
On lun, 2006-07-24 at 12:01 +0200, Maciej Sieczka wrote:
ivan marchesini napisał(a):
> Dear Users,
> B
> datum: eur50
> proj: utm
> es: 0.0067226700
> f: 297.0000000000
> zone: 33
> and
> datum: rome40
> proj: tmerc
> es: 0.0067226700
> f: 297.0000000000
> lat_0: 0.0000000000
> k_0: 0.9996000000
> y_0: 0.0000000000
> __________________
which gives:
OK?
Maciek
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
