Hallo all!
I'm struggling with the import of a shapefile. It imports more than 300 of 1200 polygons without centroid.
Is there a way to select all these areas for getting them exclusively displayed?
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
Dr. Manuel Seeger wrote on 10/31/2007 01:51 PM:
Hallo all!
First of all, check (e.g. with ogrinfo) how many polygons you
really have.
It is rather likely that you have a topologically broken SHAPE
file - in this case lots of spurious polygons will be created (since
they are present like this in the map) unless you use
- snap parameter (careful to not snap too much)
- min_area can be used to suppress small areas
or later v.clean/v.edit with approriate parameters.
Unfortunately it is rather painful to fix broken SHAPE files.
At least you have a topological GIS at hand which helps you
to identify the problems. And yes, public, official SHAPE files
are also sometimes broken (I can indicate some if you want).
displayed?
E.g., v.digit should show broken topology in red.
