This question is also posted on stackexchange.com
I have a vector map that includes 100 points. These points were created using v.extract
to randomly sample a larger map of 10k points. As such, the ‘cat’ values range from 1 to more than 10k. What I would like to do is to update the attribute table by rescaling these values to 1 to 100.
Here’s what I’ve experienced. If I use
v.category input=pts100 output=foo option=del
v.category input=foo output=pts100 option=add --o
Then when the ‘cat’ values appear rescaled when I print them with
v.category input=pts100 option=print
However, if I look at the dbtable with
db.select pts100
the ‘cat’ values have not changed (presumably because it is the key column).
So I’m thinking I will need to add a new column using v.db.addcol
, but I don’t know how to specify the range of value to populate the new column. From what I can tell, I have to specify a single value.
Ideas?
On 18/04/13 15:52, Shaun Langley wrote:
**This question is also posted on stackexchange.com
<http://stackexchange.com>**
using |v.extract| to randomly sample a larger map of 10k points. As
such, the 'cat' values range from 1 to more than 10k. What I would like
100.
Here's what I've experienced. If I use
v.category input=foo output=pts100 option=add --o|
Then when the 'cat' values /appear/ rescaled when I print them with
|v.category input=pts100 option=print|
|db.select pts100|
the 'cat' values have not changed (presumably because it is the key column).
So I'm thinking I will need to add a new column using |v.db.addcol|, but
I don't know how to specify the range of value to populate the new
Ideas?
Either
- v.distance (possibly with dmax=0) to get the cat values from the new points into the old map and then v.reclass to use the new values as cat values.
or
- v.db.addcol YourOldMap col='newcat int'
- populate that column with values from 1 to 100
- v.reclass as above
It might be an idea to add to v.category the possibility to propagate cat value changes to the attribute table. You could file a wish on the bugtracker.
Moritz
On Apr 18, 2013, at 9:48 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
100.
|db.select pts100|
Ideas?
Either
It isn't clear to me how this can be used to rescale the cat values. Points map has cat values that are (for example)
120
343
444
521
1334
I don't necessarily have to rescale the cat values if I can create a new column in which the values are scaled 1-100 (it's not feasible to do this by hand given the quantity of values I'd have to change. I need to script it.)
or
This is the kind of solution I was thinking I'd need to employ, but I need to automate the propagation of new values.
Moritz
I have a possible solution!
1. add column to new table "newcol"
2. initialize first value
val=1
3. update values incrementally
for i in `v.category foo option=print`; do
v.db.update foo column=newcol value=$val where="cat=$i"
val=val+1
done
100.
|db.select pts100|
Ideas?
Either
120
343
444
521
1334
or
Moritz
created using |v.extract| to randomly sample a larger map of 10k
points. As such, the 'cat' values range from 1 to more than 10k.
|v.category input=pts100 output=foo option=del v.category
with
|db.select pts100|
key column).
|v.db.addcol|, but I don't know how to specify the range of value
Ideas?
Either
I meant using the new vector map pts100 as 'to_map' and your original map as 'from_map' and filling in a new column in the original map with the cat values of pts100. dmax=0 should work as the points are identical.
120 343 444 521 1334
need to script it.)
If you use PostgreSQL as a data backend, you can simply create a sequence and fill up the table with calls to nextval().
I don't think SQLite has sequences as such (only autoincrement for rowid's).
Otherwise, I agree that you will probably have to script, so maybe the v.category + v.distance is actually the easiest.
Or, just thought of another possible solution (untested): use v.category to add a new layer with your ordered cat values to your original map, v.db.addtable to add a table to that layer, v.db.addcol to add a new column to the original attribute table in layer 1 cand v.db.update with qlayer and either option=cat (if this works, you actually don't have to create an attribute table for layer 2) or option=query and qcolumn.
Moritz
