Hi Martin,
Thank you for your quick reply!
That’s really crazy that you got this result!!
I have tested with Grass 6.3 AND grass 6.4(the one on which I’m working on) and both gives the exact same (wrong) results!! I’ve done again the test right now to be sure but the result is always the same: only 2 features are returned by v.edit for cat=3/layer=1. I really don’t understand what could be the problem.
Did you use any special parameter during the import (apart from setting the format to standard) ?
Personaly, I used the default values as they are set by the wxpython interface for wx.in.ascii…
The only other possibility that I can see is the OS. I’m currently testing on windows.
Are you also on windows or on Linux?!?
Tonight, I will test it on linux but it would be rather strange that it is the source of the problem…
Have you also tried to select from layer 2 ? (v.edit map=test layer=2 tool=select cats=2 type=centroid --q)
MA
-----Original Message-----
To: marc-antoine.nuessli@euratlas.com
Cc: grass-user@lists.osgeo.org
Date: Tue, 1 Sep 2009 14:25:39 +0200
Subject: Re: [GRASS-user] Possible bug in v.editHi,
2009/9/1 Marc-Antoine Nüssli marc-antoine.nuessli@euratlas.com:
But if I ask for the features with cat=3 in layer1:
v.edit map=test_shapes_newi layer=1 tool=select cats=3 type=centroid
I get only 2 ids:29,27
Selecting features…
2 of 29 features selected from vector map test_shapes_newi@PERMANENT
v.edit complete.which version of GRASS are you using? Testing GRASS 6.4
v.edit map=test layer=1 tool=select cats=3 type=centroid --q
26,27,29Seems to be OK.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
