Dear Grass members,
I apologize for any inconvenience but I am not familiar with the bug system in Grass GIG. Please let me know if this e-mail needs to be sent to a different address.
Recently, I started working with Grass GIS (version 7.4.0). At the moment, I am following the tutorial ``NCSU GIS/MEA582: Geospatial Modeling and Analysis". I came across the command ``d.mon" that does not work the way it is supposed to work. The issue is that d.mon start=wx0 does not initiate a new display window, nor does d.mon stop=wx0 terminate an existing window. Also, ``d.mon -l" or ``d.mon -p" show nothing. In all cases the commands are written in the CONSOLE window in the Layer Manager sub-window and when the Enter button is hit the following error message appears that ``Command 'd.mon' not yet implemented in the WxGUI. Try adding it as a command layer instead." It, also, needs to be mentioned that the ``d.rast map=elevation" shows the elevation map just fine. It is the d.mon that is not working! Please let me know if you need further information.
P.S. I am running Grass GIS 7.4.0 on Ubuntu trsuty 14.04 (32 bit).
Sincerely,
Nozhan Balafkan
