[GRASS-user] postgis back-end
Hi List,
I'm about to try integrating a large number of disaggregated spatial
'databases' (including actual relational dbs and scattered
spreadsheets) into a single cohesive whole and I'm looking for
suggestions - both with regard to preferred methods and reading
material (crash course versions preferably). I was thinking that I
would use postgis, but I need to know if it will be possible to
simultaneously use ArcGIS and GRASS (depending on purpose and
preference) with one postgis back-end so that I don't have to maintain
two databases in order to keep both GRASS and ArcGIS users up-to-date
individually. Any thoughts or suggestions?
Chris
Chris Carleton pisze:
Hi List,
Chris
grass-user mailing list
grass-user@lists.osgeo.org
not now about current version of arcGIS, but till version 9.2 there were no support for open-source solutions like postgreeSQL and postGIS. Only proprietary back-ends like Oracle Spatial etc. But as I know from version 9.3 there is extension "data Interoperability" (looks like warper for GDAL/OGR) so with this solution you can have access to postgis.
The second solution: Oracle Spatial as backend for Arc and link via OGR to GRASS, but it is only theoretical idea I did not test it.
J.
I have not tested this, however, it seems to enable ArcGIS to communicate with postGIS. I saw a screenshot of ARC 9.3 connected to postGIS. ZigGIS version 3.0 is said to return to OSS.
http://www.obtusesoft.com/
Mark
