When it try to run this in 6.4.3svn (last night’s build) or 6.4.2: v.in.ogr -t -o dsn=C:\Users\Aren Cambre\Desktop\DEEM documents\TxDOT\grass connection.dsn output=crashes
…all I get this this: ERROR: Unable to open data source <C:\Users\Aren Cambre\Desktop\DEEM documents\TxDOT\grass connection.dsn>
That error is vague.
The DSN was generated by v.in.ogr.qgis in Quantum GIS, and it does work in QGIS’s bundled GRASS 6.4.2. In the grass connection.dsn file is this: PG:dbname=‘de’ host=localhost port=5432 user=‘development’ password=‘XXXXXXXX’ sslmode=disable
(of course, XXXXX is replaced with the actual password)
Through running process monitor, I see that GRASS has no problem accessing the DSN file. Also, through pgAdmin III’s Server Status utility, I can verify that GRASS is not attempting to connect to the database.
On Sat, Dec 29, 2012 at 7:14 PM, Aren Cambre <aren@arencambre.com> wrote:
When it try to run this in 6.4.3svn (last night's build) or 6.4.2:
...all I get this this:
I see two potential problems:
- white space in the path (could you as experiment try from a location without?)
- maybe the (internal) management of \ escaping is incorrect?
Please try without white space first and tell us if that helps.
QGIS's bundled GRASS 6.4.2. In the grass connection.dsn file is this:
PG:dbname='de' host=localhost port=5432 user='development'
password='XXXXXXXX' sslmode=disable
work? I.e. not using the file "grass connection.dsn" but its contents.
Markus M
the DSN file. Also, through pgAdmin III's Server Status utility, I can
Made no difference: ERROR: Unable to open data source <C:\temp\grass.dsn>
work? I.e. not using the file “grass connection.dsn” but its contents.
Here’s the command that I tried to run manually: v.in.ogr dsn=“PG:dbname=‘de’ host=localhost port=5432 user=‘development’ password=‘XXXXXXXXX’ sslmode=disable” layer=“raw.TxDOT consolidated crashes” output=crashesX snap=-1 min_area=0.0001 -o
I get this dialog:
In case the dialog doesn’t come through, the error is Unable to parse command, then it repeats my command encapsulated in single quote marks.
