[GRASS-user] postgresql driver
Hi!
I have postgresql table with point data type column "mypointloc". When i have tried to create vectors (points) object in GRASS 6.2.2
v.in.db driver=pg database="localhost,dbname=aeronet" table=mytable x=mypointloc[0] y=mypointloc[1] key=myid output=mynewtable
I have got message " WARNING: pg driver: column 'mypointloc', type 600 is not supported"!
Result table "mynewtable" have not x and y columns.
How I have create vectors(points) objects from postgresql table?
Is it possible to create new vectors(points) without creation new attribute table?
Thanks & Regards
Basil
hi,
Vassily Poddubny píše v Út 26. 02. 2008 v 20:18 +0500:
Hi!
is not supported"!
afaik you have to specify two new collumns of types (float or double),
for x and y coordinates.
grass does not support "point" column type used in potgresql
attribute table?
yes, v.in.ascii should do the job
jachym
Thanks & Regards
Basil
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Hi, Jachym!
Thanks!
Jachym Cepicky пишет:
hi,
Hi!
Does you mean - it is better do not use postgresql tables with point type? It is strange for me!
OK! I think it is lucky thought. I will try to create ascii file from postgresql table and then I will use v.in.ascii.
Thank you!
Basil
Jachym Cepicky píše v Út 26. 02. 2008 v 16:17 +0100:
hi,
no, it does not (afaik) support any "point" type in any database. even
postgis implements point type on it's own. you can also store the data
in postgis and import them to grass via v.in.ogr
adding support for the "point" type for postgresql should not be that
hard...
you can also use `"SELECT point FROM your_table"|v.in.ascii out=points`
approach
jachym
Jachym Cepicky
